t5 help needed
  • Thread starter Thread starter 65notch
  • Start date Start date Nov 12, 2006
65notch
303
661 Cali
Nov 12, 2006
  • Nov 12, 2006
hey guys, im posted in here because there are alot more fox bodies with 5spds than classics so maybe u guys can help... i did the t5(brand new) conversion on my 65 notchback about 6 months ago and ever since then, i couldnt go over about 80mph without the entire car shaking and rattling, im only at 2500rpms at the mph also so i know it has to do with speed and not engine rpms. driveshaft is new, tires are balanced, rear end is fine. well today i went on a cruise in the mountians, ran my car hard shifting from 3-4-3 quite often but never really ran the rpms or mph up high. then a few hours later i was driving on the freeway at about 75 mph and i went to pass a car so i got on it, and as usual the car started to shake, rattle, etc when the mph went up, and then about halfway around the car, at maybe 80-85 mph, something odd happened and the vibration went away and she was driving as smooth as could be! there was no loud noise, clunk, or anything. so i let off the gas, and then got back into her and went to probably around 90-95(2900rpms) and she was still smooth... i continued to drive another 20 miles and then when iw as home i saw a little bit of smoke floating around so i look under the car and their is fluid dripping on the floor under the trans. i pulled my consol out so i could see be the shifter and it looks like fluid is comming out from around that the shifter bolts down to the trans case.
does anybody have any suggestions of what happened, what i should do or anything?
thanks
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Nov 12, 2006
  • Nov 12, 2006
put some RTV around the shifter base....or buy/make a gasket
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
Nov 12, 2006
  • Nov 12, 2006
Here's some great info on the T-5
V
v8only
2,378
22
49
Nov 13, 2006
  • Nov 13, 2006
are you the same guy from the maverick board?
If not, you likely used a late model flywheel on your early engine. 289's/302's used a 28 oz balance on the engines and flywheels until 1980. You've likely put a late model 50 oz flywheel on a 28 oz motor. You're gonna tear that baby up.
look for a 28 oz flywheel I believe with 157 tooth.
65notch
303
661 Cali
Nov 13, 2006
  • Nov 13, 2006
its a 28oz flywheel
65notch
303
661 Cali
Nov 13, 2006
  • Nov 13, 2006
what would cause the fluid to come out the shifter cap?
Euphoric306
905
  • Nov 14, 2006
jeremy he said it's speed correlated too. if it was anything in front of the gearbox then it would be RPM correlated
V
v8only
2,378
22
49
Nov 14, 2006
  • Nov 14, 2006
I missed that, thought I read everything from the getgo.
P
Fuel New Eldebrock 1406 problems 1985 GT 5.0
  • Paddyman
  • Oct 22, 2026
Fox 5.0 Mustang Tech Nov 2, 2026
manicmechanic007
T5 5th gear 89 gt
  • mac_55
  • Mar 19, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 20, 2026
Mustang5L5
Drivetrain 83’ Glx convertible C5 Trans help!
  • JacksonJared2113
  • Dec 25, 2025
Fox 5.0 Mustang Tech Dec 26, 2025
JacksonJared2113
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
M
85 Capri 5.0 transmission rattle
  • Mamaclean
  • May 2, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 17, 2026
Mamaclean
M
