T5 Help
  • Thread starter Thread starter back2fox
  • Start date Start date Nov 11, 2006
back2fox
73
  • Nov 11, 2006
I have an '86 Mustang GT. I bought it with a nasty vibration above 3K rpm's. What I have replaced; harmonic balancer, tranny mount, driveshaft, clutch kit w/ pilot bearing, and resurfaced the flywheel.
All of this helped but it still vibrates through the shifter above 3k rpm's. It's driving me crazy. The tranny shifts great and no noise. Could something still be wrong inside the tranny for it to do this?
Any suggestions?? Thanks
Mustang5L5
Mod Dude
Feb 18, 2001
43,382
18,125
224
Massachusetts
Nov 11, 2006
  • Nov 11, 2006
Does it happen at 3K rpm's no matter what gear the trans is in???
Black1987Stang
1,422
Jersey Shore
Nov 11, 2006
  • Nov 11, 2006
I got somewhat of the same problem or well did....I had 3 bolts holding the trans onto the bellhousing, it would have a whine in 1st gear and in 5th gear the shifter would vibrate like crazy and make a noise like something was loose, hard to explain, but I got another bolt for the trans and now its quiet and has no vibrations like it used to......mine did it only when I was above about 55mph in 5th gear....you said u replaced the clutch and all that, figuring u would have noticed if it was missing a bolt or if one of the tranny-to-bellhousing bolts was loose if u did it yourself, n if it started doing it after u just did the clutch or before
stangbear427
2,401
New England
Nov 11, 2006
  • Nov 11, 2006
When my old T5 did that it was the input bearing where the DS slides in. Check for fluid around the end of the tranny/front yolk on the DS. If that's not it, you got me.
Beasly B
165
Virginia
Nov 11, 2006
  • Nov 11, 2006
A bent input shaft can cause what your describing, may be internal.
back2fox
73
  • Nov 11, 2006
Thanks for the replies. It's worse in 1st and 2nd gear. I will be pulling the tranny back out this weekend and checking inside.
I drained the fluid tonight and it had a metallic look to it.
F
FOXtool
12
  • Nov 11, 2006
CHECK YOUR MOTOR MOUNTS, MAKE SURE THEY ARENT BROKEN OR SAGGING.
stangbear427
2,401
New England
Nov 12, 2006
  • Nov 12, 2006
Turn off your caps lock
back2fox
73
  • Nov 13, 2006
Finally figured it out. Thanks for the input.
There is a small nick where the bearing rides on the input shaft. The more pressure put on it in the higher rpm's would cause the vibration. So aggravating, well atleast now I have a new driveshaft, balancer, clutch kit, mounts....
N
Vibration after new clutch
  • nipple_looker
  • Sep 20, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 26, 2026
fasterthangas
F
L
95 gt engine vibration
  • lenzgt
  • May 11, 2026
  • 1994 - 1995 Specific Tech
1994 - 1995 Specific Tech May 26, 2026
lenzgt
L
P
2002 T5 transmission vibration issue
  • puffoo
  • Feb 22, 2026
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Feb 22, 2026
puffoo
P
Drivetrain 8.8 Pinion and 302 rear main seal leaks after replacing. 93 5.0 with t-5
  • Steigy4827
  • Jun 23, 2025
Fox 5.0 Mustang Tech Apr 1, 2026
Steigy4827
J
2004 Mustang 3.8L V6 vibrations above 65 MPH and differential leaks
  • joeybuddy96
  • Mar 16, 2026
SN95 V6 Mustang Tech Aug 29, 2026
joeybuddy96
J
