T5... now what shifter?
  • Thread starter Thread starter Nosboss
  • Start date Start date Dec 9, 2008
N
Nosboss
115
  • Dec 9, 2008
What do you guys with a T5 do for a shifter? I am converting from a toploader and I didn't like the long throw of the competition plus shifter. I am told that a T5 is a long reach if the stock type shifter is used. Any suggestions?
golf4283
1,253
Orland Park, Illinois
Dec 9, 2008
  • Dec 9, 2008
My T-5 has a b&M short throw shifter of some sort. Reach is perfect on it. At least for me it is.
M
moostangvert
47
  • Dec 9, 2008
I liked my upr a lot
68EFIvert
639
Camas, Washington
Dec 9, 2008
  • Dec 9, 2008
When I was using a T5 I had a stock shifter with a UPR Rock Crusher handle. The handle put the shifter ball in a very comfortable location. I would have replace the shifter to a UPR or Steeda unit if I kept the T5 though. I like how both of those shifters allow you to mount the handle slightly higher than most of the others. I have a Steeda shifter and the Rock Crusher handle with my T56 and the reach is perfect even when I go into 5th or reverse which is way over there with a 6 speed.
Shakin66
628
Waycross, Ga / Lake James, NC
Dec 9, 2008
  • Dec 9, 2008
I am using a t-56 also and have just the stock shifter but because my aftermarket seats I decided to try the restomod shifter and its very comfortable and sets the shifter back toward where you are sitt. Just my .02
N
Nosboss
115
  • Dec 9, 2008
I am laughing about your gas pedal. Thats because mine did the same thing three times! I welded it on everytime. The first two times I just tacked it. The last time I got it pretty hot and it has not come apart for several years now. It took a while for the rubber to settle back down after the third time.
Anyway, I forgot to add that I have a pro 5.0 shifter, I just need a handle that I can reach when sitting in the car. The one from mustangs plus has (in your photo) looks very efective, but not very appealing to the eye. Can I just get a new stick to bolt onto my shifter?
R
Rapid
297
Columbia, SC
Dec 9, 2008
  • Dec 9, 2008
Hurst makes a variety of bends and heights. I can not remember exactly which one I got but if you do a google on Hurst shifter sticks I think you will find some good options.
red302
881
Peru, IL
Dec 9, 2008
  • Dec 9, 2008
Hurst competition plus is a good unit. I have one on a T-5 and another on a Tremec 3650. Both are short throw with good feel and engagement, and like Rapid says, Hurst makes many diffenent styles of handles for them to fit the reach position you like.
voipguy
Chandler, AZ
Dec 9, 2008
  • Dec 9, 2008
I got this shift handle from Reenmachine and it works great! I bought a Pro 5.0 shifter.
N
Nosboss
115
#10
  • Dec 9, 2008
  • #10
It seams to me that with that much pull-back on the shift handle you would be shifting mor up and down. Is this true? Would you feel comfortable drag racing with that stick?
57fairlane
560
Oakwood, GA
Dec 9, 2008
#11
  • Dec 9, 2008
  • #11
Uh . . . Pro 5.0. What else is there?!?
tx65coupe
Dec 10, 2008
#12
  • Dec 10, 2008
  • #12
I am just going to use the vintage style shifter that is made to fit a T5. My friend had one and it was nice and it looks like it belongs in the car.
67rcks
373
Dec 10, 2008
#13
  • Dec 10, 2008
  • #13
I manufactured mine and had it powdercoated with other parts. Even if they used mother Theresa in their advertising I would not buy Hurst for the money they ask for it
65ShelbyClone
4,675
38
119
Antelope Valley, SoCal
Dec 10, 2008
#14
  • Dec 10, 2008
  • #14
I put a B&M in my '89 GT when I had it and liked it a lot. When I eventually go with a 5-spd, I plan on getting the better one with a bolt-on stick and using a classic Hurst arm like the one on my current Comp Plus/Toploader setup.
N
Nosboss
115
#15
  • Dec 10, 2008
  • #15
Ok, I thought I would give this shifter handle a try. After all, I got it for $20! It should give me just enough pull back on my pro 5.0 shifter... time will tell.
http://cgi.ebay.com/ebaymotors/ws/e...0321036159&sspagename=STRK:MEWNX:IT&viewitem=
R
ron67fb
1,117
SF Bay area, CA
Dec 10, 2008
#16
  • Dec 10, 2008
  • #16
What else can you share about this shifter? How does it feel side-to-side, is there any play at all between the original shifter stub and the relocated one? I'm not really a fan of the up/down movement and long throws of the longer sticks, plus the leverage that it puts into the shifter.
I had some back pain before and after not driving my Mustang for a few days, reaching for 3rd gear brought the pain back instantly. That's what caused it!
Markus
238
germany
Dec 11, 2008
#17
  • Dec 11, 2008
  • #17
I drove now about 4 years with this shifter lever from hurst and a hurst pistol grip handle. But it is very heavy and rattle very loud. Sometimes it shift from third in neutral automaticly.
Now i use a stock looking lever with a hurst 5-speed knob. I reach it better and can simpler shift in the third and 5th gear.
Markus
B&m hammer shifter c4 question
  • 387lx
  • Mar 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 19, 2026
387lx
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
D
351w swap shifter is not lining up
  • duckman0926
  • Aug 6, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 7, 2025
limp
For Sale Borg Warner WC T5, Stock Bell Housing, RAM Clutch Set, Double Hump Cross Member, & Pro 5.0 Shifter
  • AeroCoupe
  • Aug 9, 2025
  • Drivetrain Parts
Drivetrain Parts Sep 7, 2026
AeroCoupe
P
market for 2.3L? i wanna sell
  • Patk
  • Dec 6, 2025
  • 2.3L (N/A & Turbo) Tech
2.3L (N/A & Turbo) Tech Dec 7, 2025
rednotch
