Hello,
I have a couple of questions about the AOD to T5 swap. I am using a Ford Racing Clutch quadrant and cable. I have two questions for you all:
• Where do I route the cable through the firewall? What was the factory hole for routing for factory T5 cars? Did the cable go through where the factory AOD speedo cable hole is?
• Do I clip the clutch cable to the Ford Racing quadrant or does the tension of the cable hold it in place?
• On step 8 of the Ford Racing instructions, it says ‘Carefully remove the clips and springs from each of the two stock plastic quadrant parts’. What are these clips and springs? I don’t have any stock plastic parts….
Thanks in advance!
Thanks in advance!
