t5 to t45
  • Thread starter Thread starter Chris99GT
  • Start date Start date Oct 1, 2007
Chris99GT
48
Edmonton, Alberta, Canada
Oct 1, 2007
  • Oct 1, 2007
can I use a t45 out of a 98gt in a 88gt? is it just a bellhousing swap?
h8my408
93
Houston, Tx
Oct 2, 2007
  • Oct 2, 2007
why would you want to do that? the t45 is weaker than the t5... go find a turbocoupe t5... shorter gears and stronger than a t45...!!! 85 turbodeisel ranger pilotbearing...
BlownFiveLiter
have car, will race....wait, it doesn't run
18
108
Chicagoland
Oct 2, 2007
  • Oct 2, 2007
Not possible without a custom bellhousing. The T45 bolts to the bellhousing from inside of the bell, so it won't bolt to a 5.0 bell. Since the transmission bolt pattern on the block is different between the 4.6 and 5.0, you'd be hard pressed to find a solution that would be cheap.
BK_CAULEY
it's built for speed not longevity, woman
Dec 26, 2006
49
Thomasville, ga
Oct 2, 2007
  • Oct 2, 2007
what???
SVT32VDOHC
waiting for the next hack atta
3,501
28
119
Motor City
Oct 2, 2007
  • Oct 2, 2007
What is that mumbo jumbo?? First the T45 is stronger than the T5.
Now to answer the question of the thread starter. No you cannot use it. The T45 is a 3 bolt starter, and when you take the bell housing off a T-45 or TR3650, you expose the gears and the fluid leaks out. It isn't a sealed case like a T5 when you take the bell off. I get a rebuild on your T5. My rebuild is great!
h8my408
93
Houston, Tx
Oct 2, 2007
  • Oct 2, 2007
lol. sorry. i guess my opinion is not what you asked for. the only reason i think that is because i've broken more t45's than t5's. and i've NEVER broken a 4cyl tranny - weird? anyway i did not post my full response. that pilot bearing is what is needed to use a 4cyl transmission with the 5.0L
once again. sorry.
1SLO306
My 97 GTP owns you ALL!
Mar 31, 2005
904
Muhlenberg, ky
Oct 2, 2007
  • Oct 2, 2007
dont listen to guy above j/k it would be easier to find a T5 out of the fox body car or have yours rebuilt.
bhuff30
6,037
35
129
Olathe KS
Oct 2, 2007
  • Oct 2, 2007
The 4cyl T5 has a smaller diameter input shaft than the v8 T5. It is actually rated to handle less torque because of that as well. It is possible you havn't broken a 4cyl T5, because most of the 4cyl T5s didn't get the lifetime of abuse like your average v8 T5 would.
Ironically, the T45 has a higher torque capacity than the T5, even than the v8 T5. However, I can't imagine why anyone would purposely put in a T45 unless they like granny shifting. The forks are noritiously weak and make the tranny useless (no internal shift stops either).
once again. sorry.
h8my408
93
Houston, Tx
Oct 3, 2007
  • Oct 3, 2007
bhuff.. where are these ratings at? i dont see why a "detuned" turbo motor would come with a weak transmission. obviously the turbocoupe/svo/xr4ti doesnt make as much torque as a v8, but why would this not contribute to the car getting stronger components than the NA 4cyl?
bhuff30
6,037
35
129
Olathe KS
Oct 3, 2007
#10
  • Oct 3, 2007
  • #10
Of course, the factory torque ratings are much less than what the transmission can actaully handle, but the 4cyl t5 was rated at 240 ft*lbs while the v8 was rated around 300 ft*lbs most years.
http://www.fordmuscle.com/archives/2000/09/t5swap/index2.shtml
As you can see, the input shaft is a smaller diameter on the 4cyl trannys, so it is naturally weaker. Didn't you have to use some kind of bushing to make those 4cyl transmissions work?
Anyway, yes the NA 2.3 t5 was the same as the 2.3 turbo T5. Opens up a lot of possibilites for junk yard hunting, right? The 240 ft*lb rating is what the 2.3 turbo made in factory trim. However, a few small mods can get you to 300 at the WHEELS.
As I recall, the T45 was rated about 335 ft*lbs, while the T56 was rated 365 or so. There are plenty of cars coming from the factory with more torque than that and a T56 though. Dodge Viper.. 03/04 cobra... ect
These torque ratings are kind of laughable really. Realistically, unless you are launching HARD at the strip on very sticky tires, you probably arn't going to break that 4cyl T5.
D
Drivetrain Using a 98 Cobra T45 in a 03 GT Auto
  • dylan9075
  • Jun 2, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Jun 2, 2026
dylan9075
D
M
Hello, from Illinois
  • midstroke
  • Sep 13, 2026
  • The Welcome Wagon
The Welcome Wagon Sep 13, 2026
LILCBRA
A
Need some info on putting a 2002 4.6l in a 1997 gt.
  • Austin4.6l
  • May 29, 2025
1996 - 2004 SN95 Mustang -General/Talk- May 29, 2025
Austin4.6l
A
K
3.8 T5 & Bellhousing to 1987 Lincoln 5.0
  • ks65stang
  • Mar 2, 2026
  • Other Auto Tech
Other Auto Tech Mar 3, 2026
J
Foxbody trans swap
  • jimendo20
  • May 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 11, 2026
KRUISR
