Drivetrain SN95 to Fox T5 bearing retainer
93CalypsoConvert
275
91
38
Virginia
I'm building a T5 which came from a SN95 mustang with the longer input shaft. It will be going into a fox with the normal 5.0 bellhousing. I already have the shorter fox-style input shaft. I just want to double check that the front bearing retainer needs to be shortened. It should be shortened by 0.650", right? Thanks.
That is correct. I double checked myself and found a couple of solid references by builders that also said 0.650". This would be SPeace-ATL over on the Corral, nxcoupe on Modded Mustangs, Chris Neighbors down in H-Town, TX, and the guy that builds my T5's.
nxcoupe has a really good write up on the differences in the T5's here:
Reactions: 93CalypsoConvert
I would double-check with them. The steel retainer is superior in every way and cheap insurance.
Agreed and when you build something for someone whether it be a favor or for money, honestly as a builder you can't afford to cut corners or do things that could compromise your work.
Recipe for complaints or doing it twice.
