tach adapter help
brent_cosenza
70
Georgia
can someone walk me through this...i have a msd dis-tach driver..the wires are as follows..it says red is the input..and it connects to the ignition 12v supply coming from the ignition switch..red/green is the output...it connects to the coil positive wire..the black is ground..i got that..and grey is the tach output signal wire..i got that..i cant find the ignition 12v supply coming from the switch..or the positive coil wire..can someone please tell me where they're at..and how to hook up a shift light...it has a red and yellow wire...
THe red goes to any switched power source under the hood. There's a fuse box right behind the battery that if you do a little checking you'll find a switched source. If you look at the coil packs on the driver's side you'll find a common colored wire on each connector,I don't remember the color but that is the GROUND for each coil. Use the opposite wire from one of the coil's.
