Tach Going Reverse - Help Please
citmov
632
12
49
Chi-town
So here's what's happening...
when I turn the key to acc position my tach jumps to 500. Then after I start it everything seems to appear okay. Idle sits at 1100 and after it warms up it drops below 1000. But when I rev the RPM to anything over 1500 the tach goes backwards below zero.
Here's a vid of what's happening:
http://youtu.be/L9Qbixt9fXg
Some more info on my car:
- 93LX 5.0
- No aftermarket tach
- I had a shift light attached when I bought it but I took it off to see if it was wired incorrectly but that did nothing.
- MSD dizzy (I had an oem before but did the same thing)
- MSD coil (this has been on every since I've had the car)
- New Ford racing wires
- New plugs
Any thoughts on what to check or what it could be? Any help would be appreciated. Thanks!
The circuit board on the back ot the tach is toast. Good luck in finding a circuit diagram for the tach circuit board. I haven't been sucessful, but then again I haven't spent hours looking for it. If you can find a circuit diagram, for the tach circuit board, I will be glad to help you fix it.
