Here's how to wire the tach, or at least what wire connects to what.
• Red = key on power supply
• Black = common chassis ground
• White = dash lighting power
• Green = tachometer signal for standard or electronic ignitions
• Yellow = used only on Internal Coil Magneto tachometers as the signal wire
• Twin Black = (looks like a lamp cord) is used on External Coil Magneto tachometers that use an inductive pick up (#5210)
• Gray = for tachometers that use a Hi/Lo shift light. When grounded, Lo shift light point is active. When ungrounded, Hi shift light point is active.
• Blue = used on Playback tachometers to start recording (see playback tachometer instructions)
Here is the wire you must tap the tachometer into and it's location.
Tachometer Signal Wire Installation
for 5.0 engine(s)
Dark green with yellow stripe wire at ignition coil
Hope this helps.
~Alex
