Tach installed, works like crap.
  • Thread starter Thread starter pistonhead351
  • Start date Start date Sep 4, 2007
1 of 2 Next Last
pistonhead351
flim hunter
May 1, 2005
75
  • Sep 4, 2007
I got a stewart warner 5" tach with shift light for free. Its was brand new and in the Box. I got it installed, all the wiring is correct. Both the ground for the illumination and the tach are run to the battery, red to a 12v key on power source and green to the - on the coil. The tach works but as soon as it gets over 2000 rpms it jumps all over the place? i was leaning towards the coil being bad, but the stock tach works great. Do you guys see anything i did wrong here. Or is there something im missing?
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
Sep 4, 2007
  • Sep 4, 2007
something you either did or the tach is bad... make sure all your wires are tight. ..hence why you got it for free maybe
pistonhead351
flim hunter
May 1, 2005
75
  • Sep 4, 2007
actually my uncle bought it new and he gave it to me because im supposed to work on his trailer. i am dead sure that everything is right. i was leaning towards the tach being bunk myself to.
woodyy24
290
illinois
Sep 4, 2007
  • Sep 4, 2007
does it have a switch for 4-6-8 cylinders?
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Sep 4, 2007
  • Sep 4, 2007
Try putting the grounds on the fender well... Mine was touchy with the grounds
pistonhead351
flim hunter
May 1, 2005
75
  • Sep 4, 2007
no it does not have a switch for cylinders that im aware of. I believe stewart warner is diff than autometer. it reads close its not doubled or anything. where at in the fender well strype?
Bad92GT
The 5 Minute Plan Man
Jun 10, 2004
492
SC
Sep 4, 2007
  • Sep 4, 2007
i run my green wire to the positive side.. works like a charm
blackened88lx
Connecticut
Sep 4, 2007
  • Sep 4, 2007
I would look into this further. Could be under a cover on the back or something.
9
90five0oh
29
i live in robertsdale, al
Sep 4, 2007
  • Sep 4, 2007
i got a 5in with shift light for christmas but its an auto gage which is made by auto meter and it does the same thing but not all the time....its really weird
pistonhead351
flim hunter
May 1, 2005
75
#10
  • Sep 4, 2007
  • #10
the stewart warner tachs dont have loops like the autometers, they have Ppr or Pbr haha cant remember, its calibrated for a v8.
woodyy24
290
illinois
Sep 4, 2007
#11
  • Sep 4, 2007
  • #11
yep. even my 2'' sunpro tach in my cavalierrlaugh had a switch under the cover.
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Sep 4, 2007
#12
  • Sep 4, 2007
  • #12
FWIW (and IIRC), the tach in my notch (big honkin' Autogage with external shift light) had WIRES in the back that determined 4-6-8 cylinder modes. You snipped one or two of the wires depending on if you wanted it to read for 6-cyl or 4-banger modes, or left 'em all intact if you wanted 8 cylinders. Had to remove the rear cover to see this, though.
Others will mostly use the ol' switch method. Just make sure it hasn't been set to something other than 8 from the factory (or prior owner).
Also, double-check your grounds. What sort of connections did you use? I usually cheap out on most of my electronic accessories and use crimp connectors (such as with stereo stuff), but on a tach, I would VERY highly recommend using ONLY soldered connections.
If all of the above checks out, and your coil is good ... whelp, the tach is probably junk.
pistonhead351
flim hunter
May 1, 2005
75
#13
  • Sep 4, 2007
  • #13
this tach works diff than autometers. all of my connections are soldered. im giving the tech line another call tomm.
MAC'n89Blckstng
1,012
NJ
Sep 5, 2007
#14
  • Sep 5, 2007
  • #14
my signal wire hooked up to negative side of the coil
Strype
Cuthbert catcher
61
34
104
Huntsvegas, AL
Sep 5, 2007
#15
  • Sep 5, 2007
  • #15
Mine is connected to the inner wheel well with sheet metal screw. Had to drill a hole first, it's kinda tough. My first attempt was using the radio ground and it wouldn't work.
Darkwriter77
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
Sep 5, 2007
#16
  • Sep 5, 2007
  • #16
I grounded mine to the dash support frame thingymadoohickey under the radio. Just take a bit of sandpaper and rub it down to bare metal before you go screwing/bolting down your ground.
HISSIN50
34
129
Sep 6, 2007
#17
  • Sep 6, 2007
  • #17
You don't have an ignition box do ya?
pistonhead351
flim hunter
May 1, 2005
75
#18
  • Sep 6, 2007
  • #18
nope but i think im gettin one.
I
ike34
156
12
Waterloo, IA
Sep 29, 2007
#19
  • Sep 29, 2007
  • #19
Did u ever figure out why it was doing that, im having the same problem?
cevtv
1,113
Massachusetts
Sep 29, 2007
#20
  • Sep 29, 2007
  • #20
Bad ground.
1 of 2 Next Last
D
Progress Thread Calypso Green 92 LX Hatchback
  • Dakar09
  • May 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 13, 2026
rednotch
Electrical Innovate PSB-1 is DOA? Am I an idiot? All plausable. Please Help
  • Dontknowchit
  • Apr 26, 2025
Fox 5.0 Mustang Tech Apr 26, 2025
Dontknowchit
A
Resolved Electrical Help Please
  • Alabama
  • Jan 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 22, 2026
AeroCoupe
F
1986 mustang no start
  • foxyjamss221
  • Oct 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
foxyjamss221
F
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
