Tach Sticking
When I was driving to class this morning, I looked down to check the RPMs and it was stick at around 1,600...but was held there for around 5 seconds. It would then swing to the RPM that I had come to and would stick there for 5 or so seconds. Then once i had idled down at a stop light it would read from 1000 to 500-600 rpm smoothly. Then once i started gaining RPM it would start sticking again. I suspect that since the transmission (manual) was still somewhat cold that it wasnt reading right, because now that it is warmed up it seems to be working fine. Ideas? :shrug:
Thanks guys.
Was it just the gauge? Did the engine feel and sound like the RPM's were sticking? Back a few years ago I upgraded my TB and the blade would stay open for a few seconds. I got sprayed and cleaned the inside where the blade is and I never had that problem again...maybe you have some buildup there that's causing the same problem. Or maybe the throttle bracket/linkage is sticking.
