Tach stuck
  • Thread starter Thread starter Retro10
  • Start date Start date Jun 11, 2005
R
Retro10
42
  • Jun 11, 2005
I have a 93 GT, I took my car to the Ford Dealer for a electrical problem and turns out it was my fuse link and another wire in the main harness...anyrate since that fix my tach sticks....could someone tell me how to fix this?
Thanks
M
my$100project
208
  • Jun 11, 2005
This sounds really odd, but do you have any sort of hesitation miss or are you running rich? The tach is tied directly into the primary igntion system. Techs use the "tach trick" all the time for simple diagnosis of the ignition system. I'll go into more detail if you seem to have a problem.
R
Retro10
42
  • Jun 11, 2005
didnt notice anyproblems...I did forget to mention that I also redid the ignition switch since everything was pointing to that as the sorce of my loss of power...
You think it was me replacing the switch?
M
my$100project
208
  • Jun 11, 2005
It only sticks when you first start it?
R
Retro10
42
  • Jun 11, 2005
Nope all the time, even driving...when i drove it home it was stuck on 2000 but did jump to 3 for a second and got stuck there. When i shut off the car, I tapped the class and it did jerk its way down to almost 0 RPMS
M
my$100project
208
  • Jun 11, 2005
If it just "sticks" I would guess bad tach. Especially if it drops when you tap on the glass. Now if it stayed at zero and intermittantely jumped I would think otherwise. Not 100% sure though.
18mustangs
533
Virginia Beach, VA
Jun 11, 2005
  • Jun 11, 2005
My factory tac moves backwards 1\2 of the time (it'll change direction after hard acceleration), instead of spending the money on an expensive fix for the inaccurate factory tac I bought a nice Autometer shift lite tac!
--Tim
R
Retro10
42
  • Jun 12, 2005
but what gets me it was fine till I had my problem with my fuse link blowing...
Do you think that when i was pushing up on the dash area to unscrew the one side of the iginition switch iit started to come out so the tach isnt making a great connection??
M
my$100project
208
  • Jun 12, 2005
What gets me is that it stuck, even after the vehicle was turned off. And after tapping on it, it did work itself down to zero. If it was an electrical probelm theoratically it would drop to zero with no power. Sounds like a mechanical issue--probably bad tach. Anyone back me up on this?
R
Retro10
42
#10
  • Jun 12, 2005
  • #10
well started the car today and revved the engine and the tach is working again?? No clue, but is working again...I will keep and eye out and see if it acts up again.
OL' WHITEY
273
Weddington, NC
Jun 13, 2005
#11
  • Jun 13, 2005
  • #11
Mine stuck one time after overrevving the motor. It was stuck at around 6k. Here's what happened: The pedal got hung up on the floor mat and the driver (dear old dad) mashed in the clutch and looked over dumbfounded at me in the passenger seat as the engine began it's assault on the rev limiter. I finally reached over from the passenger seat and killed the ignition. The whole episode only took a couple of seconds, but it seemed to last an eternity. It's like everything was in slow motion.
Anyway, my tach took a vacation for a couple of days after that and then all of a sudden it came back to work again. This was two years ago and no problems since. Oh, and the motor didn't blow. No problems there either. 130k on the ticker now and stronger than ever.
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
Electrical Ron Francis Headlight / Alternator Harness
  • dan50
  • Apr 30, 2026
Fox 5.0 Mustang Tech Apr 30, 2026
dan50
T
Inside is completely dead
  • TunaCar
  • Oct 18, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DadLife0724
