Tach wireing
Alarus
226
Az
i have just bought a tach for my 73, i am mounting it on my colome, the question is how do i wire it, so the lights work, it has 4 wires. ground, to the coil(know where those go) and ignition, and lights, the ignition and lights are what i need to know how to hook up, do i need to splice wires?...any pictures would be greatley appreciated.
R.L.
If I remember correctly, I used one of those plastic slicing clips. (I don't know a technical name for them) I pulled my gauge cluster out and spliced the lighting wire onto one of the lights in my instrument panel.
I ran the other wire to one of the acc. fuses in the fuse box
Allright, 4 wires will hook up as followes
Red- switched 12v source
black- ground
white- headlight lead
green negative side of coil
Do ya have a volt meter? this makes it easier to figure out what fuse is coming on with the key, or you can plug and play lol But i have all my 12 volt wires going to the fuse box. As for the light there should be a wire coming from the switch.
