tach wires
Black331Stang
1,485
Long Island, NY
hey, hope everyone had a good holiday...i got a tach and i tried the search with no results and that thing is a pita anyway...
anyway..what is the best place to run the red 12V wire to? fuse box, + coil, radio remote turn on? if u suggest fuse box, which # should i go to? and did u guys drill a hole for the tach wire or just run it thru where teh throttle cable goes?
thanks for any help.
o and i have a stock coil and really havent insopected it yet....is it like the after market ones with little posts? is it some like just ge the wire on or do ii have to cut wires? thanks
I just hooked it into the radio on the fuse box. Don't remember the # off the top of my head though. I ran the green wire that goes to the coil through the grommet already in the firewall where the factory harness goes though.
I just soldered the green wire to the negative side of the coil wire (can't remember the color off hand). There was already a slit in the soft rubber part behind my gas pedal, so I just ran it through there. I hooked the positive side to a 12v source on the back of the fuse block (with the key on).
oh yeah, you may want to revise your auction on ebay! Ebay rules are, "you can't list an item and offer it as a trade off of ebay." I only know because I did the same thing and ebay contacted me and ended the auction, cancelling all bids. Just looking out for you...
