tail light problem
  • Thread starter Thread starter bluegt500kr
  • Start date Start date Apr 22, 2009
bluegt500kr
37
Alabama
Apr 22, 2009
  • Apr 22, 2009
I'm having tail light issues and need some help. My brake lights and tail lights (with the light switch in either park or headlamp position) are inop. My flashers and turn signals work fine. Any ideas??
ga289stocker
238
Sugar Hill, Ga
Apr 22, 2009
  • Apr 22, 2009
May need to replace the brake light switch on the pedal under the dash. I had to in my 65 some years back. They do go bad.
Tim65GT
1,149
West Texas
Apr 22, 2009
  • Apr 22, 2009
The common point is the Headlight switch, but you may have two separate issues. I would start checking for voltage using a test light at the light switch.
Here is a diagram
bluegt500kr
37
Alabama
Apr 22, 2009
  • Apr 22, 2009
checking switch
thanks for the ideas. I have already replaced the brake light switch so I think it is okay. the problem has gradually gotten worse so it probably if the headlight switch giving it up. I am going to check it anyway. As for voltages, is there a minimum reading that is acceptable other than 12 volts? Probably a dumb question but I had to ask.
Tim65GT
1,149
West Texas
Apr 22, 2009
  • Apr 22, 2009
If you have not charged the battery in a while and there is a drain on the battery, (such as your door open and the courtesy lamps are on). The voltage may drop below 11 volts or so, but could still be plenty to crank the starter.
For troubleshooting purposes, 10-12 volts would be good. That is why I mentioned a test light. If there is enough volts to light the lamp in the test light, find the next point down the line and check.
68 headlights hot working
  • Butchd88
  • Aug 1, 2026
1965 - 1973 Classic Mustangs -General/Talk- Aug 3, 2026
Butchd88
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
M
Aftermarket Brake light help needed
  • Mustang Steve
  • Mar 17, 2026
2005 - 2014 S-197 Mustang -General/Talk- Mar 17, 2026
Mustang Steve
M
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
L
2001 cobra sequential tail lights
  • lking78
  • May 26, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 14, 2026
lking78
L
