tail light socket for 68
  • Thread starter Thread starter growth
  • Start date Start date Dec 6, 2008
G
growth
18
  • Dec 6, 2008
I am wiring a completly gutted out 68 and have a new Painless wiring kit but need the tail light sockets. I got some that said would fit the housings but they don't . They say they replace Ford part number D3AZ-13410-G but like I said they don't fit the tail light housings. Any help?
hhead
280
so cal
Dec 6, 2008
  • Dec 6, 2008
I think the part numbers you're looking for are # D1AZ-13410B and D3AZ-13410A.
It's on ebay right now http://cgi.ebay.com/ebaymotors/1967...emQQimsxZ20081204?IMSfp=TL0812041310008r15183
Which is for two. I've seen 'em for $6ea.
G
growth
18
  • Dec 6, 2008
Got them. Thanks alot!
G
growth
18
  • Dec 12, 2008
I got the new sockets but they have a white and red wire on them. Which is for the turn signal and which is for the tail lights? My wiring diagrams don't say.
l1k2gadd
53
Summerfield, Florida
Dec 26, 2008
  • Dec 26, 2008
Do you have a battery charger? If so, put the battery charger on it's lowest amperage setting (2 or 6 or 10 amps). Put a light bulb (1157) in the socket making sure the bulb's alignment marks are correct, and turn the bulb and lock (turn) it in place in the socket. One groove in the side of the socket is longer than the other so be sure the bulb is installed correctly. If the bulb doesn't want to turn take it out and try to install it the other way. Clip the black (negative) battery charger clip on the steel of the socket housing and touch the red lbattery charger clip to the red wire and then touch the red battery charger clip to the white wire. The brake light filament will be much brighter than the parking lights filament. Note the brighter one and connect it to the correct harness wire.
L
2001 cobra sequential tail lights
  • lking78
  • May 26, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 14, 2026
lking78
L
  • dan50
  • Jul 18, 2026
dan50
J
  • JasonB66
  • Jul 23, 2026
  • Suspension
Suspension Jul 23, 2026
JasonB66
J
Electrical Headlight harness trouble
  • 1985fox
  • Apr 14, 2026
Fox 5.0 Mustang Tech Apr 17, 2026
AeroCoupe
I
2000 GT Mustang - Transmission Cooler to Radiator o-rings
  • Iwarrior
  • Oct 4, 2025
1996 - 2004 SN95 Mustang -General/Talk- Oct 4, 2025
Iwarrior
I
