  • 1994 - 1995 Specific Tech
tail lights half working..
  • Thread starter Thread starter gradient
  • Start date Start date Aug 15, 2004
G
gradient
52
  • Aug 15, 2004
Ok.. annoying problem.
my 95GT's tail lights will come on when i turn the head lights on, but when I use the brakes, only the center brake light on top of the trunk comes on.
the turn signals don't work in back either.
could the bulbs be messed up so that they half way work like this? or can it only be a wiring problem?
i already checked the fuses....
thanks
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Aug 15, 2004
  • Aug 15, 2004
I would check the bulbs. It’s weird that the running lights work but not the brake or turn signal. You may have a bad multifunction switch if the bulbs are good that would be my next guess.
mo_dingo
20+ Year Stangneter
Aug 26, 2003
3,031
Tucson, AZ
Aug 15, 2004
  • Aug 15, 2004
If they are two stage bulbs, the second stage of the bulb could be bad, while the first stage is working fine. Yank the bulbs and find out for yourself.
Scott
xr8d302
I bought a 27" monitor to compensate for my lack o
Apr 29, 2004
1,113
Medicine Hat, AB
Aug 16, 2004
  • Aug 16, 2004
worst comes to worst, do the good ol check behind the light wiring cluster, might be something melted, happened to me and some other guys before...check it out, takes around 20 mins at my skill level, which is the same as a grade 2.
Resolved Electrical mayhem
  • 2000ElectricGreen
  • Mar 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 4, 2026
2000ElectricGreen
A
1966 Mustang coupe / Brake lights and left rear turn signal not working.
  • ArizonaRob1966
  • Nov 3, 2025
Classic Mustang Specific Tech Dec 24, 2025
Mcmahst
T
Need help 67 hazard flashers not working
  • THS70
  • Jan 21, 2026
1965 - 1973 Classic Mustangs -General/Talk- Jan 29, 2026
P
Is it normal for all of this to go wrong or did I get played when I bought this ONLY A MONTH AGO.
  • ponygal02
  • Nov 14, 2025
1996 - 2004 SN95 Mustang -General/Talk- Nov 14, 2025
C
Lighting issue
  • ChrisCruz1972
  • Jul 2, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 3, 2025
AeroCoupe
