If its the same as a 98 it should be easy. Take off the tire, romove the the bolts (5/8" i think) that keep the caliper in the housing....that should be it. If you have to change rotors, then take of the housing which bolts from behind the rotor to the rearend. If you must take the brake line off its like a 7 mm wrench. Hope this helps
Mario
