Taking the plastic out for roll bar install
Busted07
I need my gorilla to be about an inch longer.
Nov 15, 2005
I already have the front seats out, the lower part of the back seat, the carpet, everything out of the hatch etc... is there an easy way or anything i should know before i remove the plastic that goes from the door jamb to the back of the hatch? or is it just pull the screws and yank it out?
The roll bar is a 6 point and the 2 back bars go through the speaker holes and mount to the shock towers..., anyone have any pictures of how i can do a clean install on those without leaving the speaker grilles off?
Kabuki_notch said:
sorry i dont have any pictures but my buddy ran his through the speakers and he just used tin snips and cut out the holes it looked perfect I will try to get some pics tommrow night of his car so I can show you.
I guess im having a hard time with the whole process of getting them on there.. i have to put the halo and 2 back bars in there today, bolt them together, then take it all out and leave it for the welder to weld on saturday. then after he welds the 2 back bars to the halo, im giving it to the painter to paint a gloss black.. which will be a pain in the ass if i have a speaer grille hanging on each side. then i gotta put it in the car so he can weld it to the floor / shock towers. Im thinking it might be easier to just cut a hole in the middle, then a line straight across to the side so i can put them on after its installed... grrr
FarBeyondDriven said:
I would, but the bottom plate for that back bar already has the plate welded to it... ill take some pics in a little bit.
yeah. sicne its a gril you can slip the plate threw the grill if you turn the plate aup and down and slide the car over it. ill ask my todd to get some pics of his. thats how we did his. slip it thre the grill and then it was done.
