CobraRed_96_GT
I've wanted to get it on a dyno but have not.....I figured I'd take care of that at AMP when I do the other mods. It's a more of a logistical problem to get it on one because of where I live.
However, the tranny has behaved the same since i bought the car...I put on about 300 miles before the mods below and got a good feel for it's characteristics. The mods have done nothing to amplify or lessen the ill effects.
04 YELLOW. Sorry if I'm being redundant and slightly ingorant on this matter........but maybe you can help me clarify.. .. Why are you going with a lower stall than most people on here are running/recommend....Maybe it's just the particular posts I've run across doing research. But it appears most people on here are running tc's between 3200-3800, and most with moderate mods... You having said that you're looking at that lower range.. are the first person that intends to go with something that's even relatively inline with what these shops are recommending for me. any insight you can give me to why would be awesome![]()
unless im mistaken, from his other posts it seems he's going lower stall for traction reasons. A stall helps your 60' but you need traction to benefit from it, if you go too tall your going to get even worse of a time. Also with boost your torque is already a lot higher than normal, so amplifying the torque w/ a TC is even more of a hurdle to get over when attempting traction. Most NA go 3200-3800 cuz we can get away with that easy on slicks, but when your TC starts multiplying torque in the 400's there's not much you can do to stick the launch (if you want to launch at your power range rpm's) w/out lessening the stall rating.
