whoa, still aliveIm working on the same setup with The Tarus Fan and Northern Radiator. Question for you. What did you use for the lower hose? The radiator has that
funky angle on the lower inlet. Did you cut heater hose and intall it around the
orginal shroud you cut to make the radiator fit?
Thanks
I used a stock lower hose and the angle didnt hurt too much. If you weld or know a welder you could probably make a "pie" cut on the bottom of the outlet,bend it and reweld it.
. The car cools better at a idle then driving,and never loses a drop of water.Im sure a more mild N/A will run cooler then mine
