Taurus Fan Wiring?
  • Thread starter Thread starter stangzroastrice
  • Start date Start date Sep 19, 2005
stangzroastrice
278
Belmar, NJ (Jersey Shore)
Sep 19, 2005
  • Sep 19, 2005
Hey guys, wondering if this setup will work...
Because I'm on a huge budget I'm wondering if I were to just wire the low speed setting of my 3.8 Taurus Fan (I'm running a 2 core aluminum radiator, so I'm sure this should be efficient for my 347) like this...
Running 10 gauge wire from the hot lead to a 30amp buss circuit breaker, to a 30 amp switch inside the dash, back out the firewall onto the solenoid. And of course, running a 10gauge wire from the fan to somewhere on the fender or something as a ground. Would this work because from what I hear, the low setting on the taurus fans draw anywhere from 10-15 amps, so I don't think the initial startup (shouldn't be anymore than 30 amps) would burn this budget setup up would it? let me know thanks
sgarlic
3,085
Sep 19, 2005
  • Sep 19, 2005
I think it sounds like the setup itself would work.. but I personally would prefer to use a relay & a circuit breaker instead of just a circuit breaker. That way you just use your toggle switch to control the relay, and let the relay do the messing with the voltages.. just my opinion, but bump for you.
stangzroastrice
278
Sep 19, 2005
  • Sep 19, 2005
true, thanks man, anymore inputs?
85_SS_302_Coupe
6,945
1,598
223
Northern KY
Sep 20, 2005
  • Sep 20, 2005
Credit to FiveOhhStang for creating the little diagram
Resolved Wiring electric fan
  • cbac89
  • Aug 29, 2026
cbac89
  • dan50
  • Jul 18, 2026
dan50
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
F
AC Compressor Power & Contour Fans
  • Fri Guy
  • Aug 27, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 15, 2026
BoostedRed89gt
D
6G alternator pigtail wiring help needed
  • Dogman_1969
  • Aug 11, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Aug 11, 2025
Dogman_1969
D
