• Community Forums
  • Regional Forums and Event Information
Tech question
  • Thread starter Thread starter SMOKEDYA
  • Start date Start date Apr 10, 2006
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Apr 10, 2006
  • Apr 10, 2006
So i put my battery to the trunk, but not in a box. Will this pass tech at PIR? It is secured just as good if not better then in its original location under the hood. peace
john
Scooby5.0Doo
That's the fastest $400 car out there
Jan 9, 2003
833
beaverton
Apr 11, 2006
  • Apr 11, 2006
i think you also are supose to have an outside power switch but not for sure
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Apr 11, 2006
  • Apr 11, 2006
I have a outside power switch that does kill the electric and the engine when switched to the off position, i've already checked it. I dont know if it makes a diffrence but it is one of the optima batteries thats suppose to be spill proof. peace
john
KyleL
18
Bonney Lake
Apr 11, 2006
  • Apr 11, 2006
I just went through making my battery relocation NHRA legal. According to the 2006 NHRA rulebook, you don't need a battery box if you have a .024 steel or .032 aluminum bulkhead (including package tray). Otherwise, you have to have an NHRA-approved poly box or a box made of the above steel/aluminum, and it has to be vented outside of the car. This is in addition to a battery cut-off switch that cuts not only the battery power, but also the alternator feed. Also, you can't use J-hook type battery hold downs, and it has to be 3/8" min diameter, and you have to use metal to hold the battery in place (no plastic or rubber).
Whew. Lots to do. My set-up is an aluminum bulkhead, some 7/16" threaded rod, a steel 1" strap to hold the battery in place, no box, and a battery switch with an extra post that cuts the energizing wire on the alternator to kill the car when switched off.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Apr 11, 2006
  • Apr 11, 2006
Can you post the pics of it? If not then email them to me and i can do it for you, just let me know and i can give you my email. peace
john
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Apr 11, 2006
  • Apr 11, 2006
Iwill post mine here soon and you can tell me what i'm missing ? If anything. peace
john
Electric water pump wiring
  • 387lx
  • Feb 10, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 11, 2026
90trunk
Electrical Starter solenoid out of space?
  • 387lx
  • Jan 22, 2026
Fox 5.0 Mustang Tech Jan 23, 2026
387lx
Fox Jump/start - Charging
  • PonyGTrider
  • Oct 12, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 13, 2025
PonyGTrider
M
12 mustang gt check charging battery light
  • millerj7950$
  • Jan 24, 2026
2005 - 2014 S-197 Mustang -General/Talk- May 14, 2026
BossHorseGirl
84 turbo fan not working.
  • bdub_mkg
  • Jan 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 2, 2026
AeroCoupe
  • Community Forums
