  • SN95 4.6L Mustang Tech
teksid block into 2v??
  • Thread starter Thread starter Sanco213
  • Start date Start date Apr 13, 2009
Sanco213
23
  • Apr 13, 2009
im sure that this has most likely been covered already...and for that i apologize..lol.. but i am building a 2v and want to use a teksid block for the apparent reasons. so what is necessary to change on the block itself to use the 2v parts.. i have read in other forums that the block has to be modified to use the 2v heads.. so anyone that has done this please help. i would just like to know what i am getting into before i start.
NO BRAKES
129
Avon Lake, Ohio
Apr 13, 2009
  • Apr 13, 2009
use the 2 valve parts off your old motor on the teksid. or buy new ones. but its a modular 4.6. it should be the same.
blkhorse
345
Apr 14, 2009
  • Apr 14, 2009
you have to drill a coolant passage on drivers side,just lay a head gasket on it and you will see where. the timing components are different,dowels and guides. not sure of exact parts needed but ones from an alum. block 2v should work(explorer?)
Sanco213
23
  • Apr 14, 2009
i live in new jersey and i think im gonna look into some guys that specialize in stangs and talk to them about it...
'03GTinFLA
486
St. Petersburg, FL
Apr 15, 2009
  • Apr 15, 2009
Don't forget to post up what you find out. Thanks.
Block draining
  • JD1964
  • Mar 27, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 27, 2026
JD1964
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
  • Gulftown980x
  • Jul 29, 2026
squeak93
J
Engine 4.6 Running rough at half throttle
  • jake411
  • Aug 3, 2026
SN95 4.6L Mustang Tech Oct 20, 2026
DangStitches
D
