Temp At 220+
  • Thread starter Thread starter Alarus
  • Start date Start date Jun 22, 2005
Alarus
226
Az
Jun 22, 2005
  • Jun 22, 2005
I was on my way home earlyer today and noticed that my temp was above 220, the first time i had the car off for a few min and then got back in it and noticed that the temp was up there, so i started it and it went down to about 190 witch is normal, but then on the way home the temp went back up (this was after a mountin, so i dont know if it went up going up the mountain or what, but i had it in nutral going down hill when i noticed it.
Could this prob. be the a/f mix, my dad and i went out and adjusted the dwell and then he started messing with the mix screws leaning it out, so thats why im thinking it might be that, i had a RC car that if you had it to lean it would over heat and seise up.
10secgoal
2,801
San Diego
Jun 22, 2005
  • Jun 22, 2005
The screws you speak of only adjust the idle mixture A/F. They won't do anything for except for at idle, and just before tip in of the main jetting system. If it always cruises around 190, and only does this going up the hill, it would seem a more efficeint cooling system would be in order.
iskwezm
4,159
20
79
Rowland Heights,California
Jun 22, 2005
  • Jun 22, 2005
well it was pretty damn hot and going up a hill is more of "load" or strain,so the extra heat sounds normal
Alarus
226
Az
Jun 23, 2005
  • Jun 23, 2005
thats just it its never done it except for today.
G
grego37
576
Fresno CA
Jun 23, 2005
  • Jun 23, 2005
Totally not true.
The air/fuel mixture screws do exactally as they sound , adjusts the ratio of air to fuel. If they're adjusted too lean your car will run too hot, you can even melt pistons.
Cooling tips (even in Arizona):
Run the biggest radiator you can fit (alum. cross flow)
Run the highest Lbs. radiator cap your radiator will allow.
The biggest, highest flowing electric fan you can find.
160 or 180 thermostat
Stewart Components water pump (flows 40% more than stock)
Overdrive water pump on a street car. (upper pulley is smaller than the lower)
Proper timing and proper air/fuel mixture are also important.
http://stewartcomponents.com
thehueypilot
1,084
Medina,Tennessee
Jun 23, 2005
  • Jun 23, 2005
grego37 said:
Totally not true.
Oh Boy.................10secgoal is 100% correct
10secgoal
2,801
San Diego
Jun 23, 2005
  • Jun 23, 2005
DOH! That has to sting. Oh well. I don't sell tires..maybe I should sell carbs.
Alarus, I think at most all you need is a good aluminum rad. Even with a stock pump, fan, and everything else, it should easily hold your 190 deg you want. Your not cooling a nascar in AZ. The summit cheapy rad is really a Northern. I put that on and ran 160 dead on in 29 palms. It gets hot there too. 115 deg...still at 160, and this was not a stock motor, basically what I have now, but had RPM heads and not the ones I run now.
G
grego37
576
Fresno CA
Jun 23, 2005
  • Jun 23, 2005
grego37 said:
Totally not true.
My Bad!
sorry, 10secgoal was absolutley correct and I was wrong. I apologize.
The air/fuel mixture screws effect the idle circuit only.
Thanks hueypilot for correcting me
baskin
152
Jun 23, 2005
  • Jun 23, 2005
When you adjust the dwell, you also effect the timing. Given that the car started overheating the same day that you did the adjustment, that's most likely the problem.
10secgoal
2,801
San Diego
Jun 23, 2005
#10
  • Jun 23, 2005
  • #10
No worries Grego
G
GNN60GT500
1,218
26
48
5 car lengths in front of you!
Jun 23, 2005
#11
  • Jun 23, 2005
  • #11
Also, you may want to look at an external oil cooler....made a big difference on my 67-
thehueypilot
1,084
Medina,Tennessee
Jun 23, 2005
#12
  • Jun 23, 2005
  • #12
10secgoal said:
No worries Grego
Same here!
Alarus
226
Az
Jun 24, 2005
#13
  • Jun 24, 2005
  • #13
well so you know i adjusted the a/f ratio and took it out, didnt go over 195, got it up to about 85mph (have a long starit not traveled by others) and cept it there for a few sec, still never overheated. got the temp down even more yesterday by adjusting the timing.
G
grego37
576
Fresno CA
Jun 24, 2005
#14
  • Jun 24, 2005
  • #14
Great news!
L
A/C doesn't work after long drive
  • lking78
  • Jun 23, 2026
  • SVT Tech Forum
SVT Tech Forum Jun 30, 2026
W
High Cylinder Head Temp - Not Overheating?
  • wtfwork12
  • Jun 26, 2025
2K
2005 - 2014 S-197 Mustang -General/Talk- Jul 1, 2025
wtfwork12
W
Resolved Got Too Hot!!!
  • PonyGTrider
  • Apr 27, 2025
Fox 5.0 Mustang Tech May 6, 2025
PonyGTrider
J
Car won’t start
  • JLB
  • Nov 15, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Nov 15, 2025
nickyb
W
Megasquirt base tune for 94 5.0
  • wrx757
  • Mar 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 6, 2026
wrx757
W
