temp & fuel gauges not getting power
stangman16
640
San Antonio, TX
'66 Mustang coupe
Some time ago my temp & fuel gauges quit working. Checked for voltage at the back of the cluster and I'm not getting anything at the fuel gauge (or temp). Ran a 12v wire from the battery to the fuel gauge and it started rising.
So I tested for 12v at the CVR on the instrument bezel, one side shows 12v, the other was fluctuating between 4-6v. As soon as I get home I'm going to check the voltages again - because it appears the CVR is what powers both those gauges, and if I'm getting the correct voltage coming from there than it should work.
What are some other things I can check to solve this issue?
Constant Voltage Regulator is bad. I get this call all the time (I work at one of the leader Mustang Parts retail stores). I'd put money on it being the CVR.
I checked it once more, 1 side is 12v, the other bounces from 0 to 5, 4, 0. Guess it is the culprit - though you would figure the gauges to read something with it bouncing between those values..
found this writeup: http://www.stangnet.com/mustang-forums/774198-how-make-solid-state-instrument-voltage-regulator.html
And will try the radioshack mod
