  • SN95 4.6L Mustang Tech
Temp Gauge
  • Thread starter Thread starter mwalters
  • Start date Start date Jan 6, 2012
mwalters
15
SE Michigan
Jan 6, 2012
  • Jan 6, 2012
Ok, I have another (hopefully not stupid) question: The temp gauge always stays on cold, the the engine is clearly running at normal temp, because a) I get heat from the heater, and b) it's not overheating. I replaced the coolant sensor hoping that would be a simple fix, but no luck. Any ideas?? Thanks in advance!
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
U.S.A, U.S.A., U.S.A.!
Jan 6, 2012
  • Jan 6, 2012
You need to state the year and model of your Stang so that the better "gremlin shooters" can help you properly. If your temp sensor was not working, (99-2004 Stangs) the fan would continously run and you would throw a OBD-2 code.
I'm shooting in the air but sounds as if you have a gaug-cluster problem, not temp sensor issue.
You can always test your cluster needles by holding the mileage button when while turning the ignition to the on power position, if your temp needle does not rotate to the right completely, then you know what the source of the problem is.
Reactions: JhMustangGT03
GDawg
1,469
Nevada
Jan 6, 2012
  • Jan 6, 2012
Check your thermostat. Sounds like it's stuck in fail safe. Cheap to replace. I just fixed my sons Taurus with the 3.8l v6.
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
Jan 6, 2012
  • Jan 6, 2012
Thermostat has nothing to do with the temp-sensor's functionability.
Hes got electrical "gremlins, hes not the only one whose temp-sensor is stuck to the left.
mwalters
15
SE Michigan
Jan 7, 2012
  • Jan 7, 2012
Ok, sorry about the incomplete info. Car is a 2000 GT with the 4.6 manual. I was kind of leaning toward a cluster problem too, but I was hoping it was something simpler. I still need to check the fan function, but I haven't noticed anything out of the ordinary on it yet.
GDawg
1,469
Nevada
Jan 8, 2012
  • Jan 8, 2012
Whatever you say... my kids Taurus had the temp gauge stuck to the left. Replaced the thermostat and now it comes up to normal.
mwalters
15
SE Michigan
Feb 26, 2012
  • Feb 26, 2012
Ok, I finally got around to looking into this further. I replaced the thermostat with a Stant 190 degree (stock temp), and now the gauge works!! Fan comes on at the proper time too, although I don't know if it was incorrect before. I dunked the old thermostat in boiling water and it opens and close fine...maybe it was a lower temp part?? Anyway, the temp gauge works now, so I'm happy!
trombonedemon
Well-Known Member
Jun 25, 2009
1,962
39
59
Feb 26, 2012
  • Feb 26, 2012
I'm standing corrected!
GDawg
1,469
Nevada
Feb 29, 2012
  • Feb 29, 2012
That's cool. I did the "boil in coolant" test before I replaced it.
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
C
Electrical Fuel Gauge...Help! What did I do or Didn't Do?
  • ChickenDeluxe
  • Sep 3, 2026
Fox 5.0 Mustang Tech Sep 3, 2026
ChickenDeluxe
C
G
2016 GT, Cold Air/Tune Trouble (overheating) . Advice/Help Please!
  • GLStang
  • Sep 6, 2025
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Sep 6, 2025
J
'96 Cobra: A/C gets weak and engine misfires under load when warm
  • jruhnke
  • Oct 22, 2025
  • SVT Tech Forum
SVT Tech Forum Nov 20, 2025
nickyb
C
Resolved Coolant temp gauge issue
  • csracing
  • Jun 14, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 24, 2025
csracing
C
