Testing a Starter Solenoid
FordRacing302
5 Year Member
Oct 1, 2005
384
42
59
Cleveland, TN
Well Im not that good at wiring and when I was wiring up my coil, I wired it dierctly to the solenoid, and I think I blew the solenoid because before I touched the wires the motor turned over fine but now It wont....So is there a test I can do to find out if my solenoid is bad??
if the 83's starter solonoid is similar to the 87-93's, you could take a screwdriver and connect both studs on the solonoid. Make sure you have the car in neutral and the parking brake set and/or the wheels chocked because the car should crank and it might jump; might be a good idea to unplug the coil wire so that it definately won't start.
If it doesn't try to crank at all after trying it a couple times to make sure you're making good contact, it might not be the solonoid; this is only if it's like the later fox body cars as I'm not sure if it is or not.
Hope this helps
James is right. Applied to later model solenoids, if you can remove the slide-on terminal and jump it to the battery lug on the solenoid, and the car starts (observe ALL the safety precautions he outlined above), the solenoid is fine.
If that test fails but it starts by jumping the lugs like James outlined, then the solenoid is likely bad.
Good luck.
