testing ciruits with no battery?
  • Thread starter Thread starter mtaqua
  • Start date Start date Apr 16, 2011
mtaqua
345
  • Apr 16, 2011
I am starting to wire my car, and I don't won't to put a battery in just yet. I am doing a complete re-wire and would like to be able to test as I go. Any ideas without a battery? I have a low amp trickle charger, could I use that?
Andrew
j_lutter31
79
Central South Dakota
Apr 16, 2011
  • Apr 16, 2011
I guess you could check continuity of everything if you have long enough leads.....
mtaqua
345
  • Apr 16, 2011
well I want to check things like bulbs, wiper motor, etc. maybe just need to get a battery.
MustangB
31
Central Florida
Apr 24, 2011
  • Apr 24, 2011
Continuity
Use a continuity test at first. If you have continuity, you'll know voltage will pass. That said, you can have continuity and still not be able to pass the required voltage, so this is just a test. Once you get all your wires in, you'll be able to load test with the actual battery.
If you want, you can wire in a tiny 9v battery and use that to test your bulbs and such. They won't be bright, but you'll see a glow at least. Obviously, it won't be able to power the wiper motor or headlamps, but the other low amp draw circuits will work. And the amp output of that 9v is so low, that you won't start any fires if you get something really wrong. But in reality, you don't really need the 9v setup since checking continuity will get you on the path to start testing with the real battery.
tx65coupe
Apr 25, 2011
  • Apr 25, 2011
Do you have a riding lawn mower battery you could borrow? Another option would be hooking jumper cables to your daily driver to the battery cables in the Mustang. I have also done this with a battery charger hooked up to the cables with no battery. I know that wasn't the greatest idea, but it was only for a few seconds.
NasaGT
1,993
Virginia
Apr 26, 2011
  • Apr 26, 2011
Do you have any older portable electronics? The wall plug for older stuff used to be 12v for everything, you plug that in and connect to the battery terminals. Not alot of amps, but enough to check circuits. RC car batteries are 12v too, you could use one of those chargers.
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
