  • SN95 4.6L Mustang Tech
Testing for a miss
  • Thread starter Thread starter woodly1069
  • Start date Start date Dec 10, 2007
W
woodly1069
  • Dec 10, 2007
Can anyone tell me how to check the coil on plug assembly, preferably while the car is running. I have a miss I can't seem to find and I have changed the plugs, air and fuel filters. Also, can I check the injectors? I have no "Service Engine" light illuminated. Thanks in advance!
2000fordstanggt
404
Westland, MI
Dec 10, 2007
  • Dec 10, 2007
unplug a cop one at a time until you get no change in idle. thats where the problem is.
im sure someone will add to that.
W
woodly1069
  • Dec 10, 2007
duh, I guess that's pretty logical! Can' t believe I didn't think of that. Thanks!
Smokeurhonda
457
Maryland
Dec 10, 2007
  • Dec 10, 2007
The only problem with that is that will only detect a complete, consistant misfire. These are finiky coils that like to act up especially when water gets in them. The best thing to do is loosen all the coils and with the car running pull out one at a time and ground it to the metal cylinder head. Hold the tip of the coil about half inch away from the head. You should see a good half inch of blue spark. If you can't get that much distance, or if it's a yellowish white spark you have a weak coil. You might only be able to test one bank at a time due to the placement of the intake. So test all of bank 2, then switch the coils from one bank to the other and test those. You should see if you have an ignition problem.
2000fordstanggt
404
Westland, MI
Dec 11, 2007
  • Dec 11, 2007
do you have a tune installed? if so that could keep the dtc from showing up.
W
woodly1069
  • Dec 11, 2007
I'm not sure, I bought the car second hand. I did hook up an OBDII scanner and it showed nothing as well.
F
ForPointSex
395
Mercer, NJ
Dec 11, 2007
  • Dec 11, 2007
The only way to fix it yourself is get a new one from ebay ($30) and swap them out 1 by 1. I had a bad one and it ohm'd out fine. It also worked normally on idle.
You can also take it to the dealer. They have a computer that will check each one on the scope.
Smokeurhonda
457
Maryland
Dec 12, 2007
  • Dec 12, 2007
NO you do not need a new one... Look at my previous post to detect good and bad coils.
bdcardinal
tree hugger
Jun 10, 2003
3,612
santa barbara, CA
Dec 12, 2007
  • Dec 12, 2007
man its so much easier for me to test them, i never even have to touch coils, o well, IDS ftw.
  • Gulftown980x
  • Jul 29, 2026
squeak93
I
Engine Help requested in identifying how to resolve engine light issue
  • Ianslaney
  • Oct 4, 2026
SN95 4.6L Mustang Tech Oct 4, 2026
Bullitt347
Help! Fox with idle issues
  • bbarton
  • Sep 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 12, 2026
AeroCoupe
M
Electrical 93 5.0 No Injector Pulse
  • machinermac
  • Jul 26, 2026
Fox 5.0 Mustang Tech Aug 1, 2026
Willybill32
Code p0204
  • 04blckstang
  • Nov 23, 2025
SN95 4.6L Mustang Tech Nov 25, 2025
squeak93
