Testing gas gauge
  • Thread starter Thread starter madbrad
  • Start date Start date Sep 1, 2005
M
madbrad
72
Albuquerque NM
Sep 1, 2005
  • Sep 1, 2005
I just put in my new auto meter gas gauge and when i turn the ignition on it barley moves. I put 10 gallons of gas so it should move more than that. Im thinking it might be the sender ans i bought a digital voltmeter to read the omh's but not sure how to do it, or what it sould read. Any other ideas on things to check? I dont know if the gauge work before i install the new gauges since the car was just a rolling chassie when i got it.
Thanks
Bullitt
Packin' Heat
2,743
Houston, TX
Sep 1, 2005
  • Sep 1, 2005
summit lists the resistance reading for the various autometer gauges. you have a "ford" style, so just look up your gauge in summit.
as far as measuring resistance. put your voltmeter on 0-200 ohms and bridge between the sending unit and a spot on the frame. that should give you the gauge reading (if i remember correctly). it's either that or you disconnect the sending gauge wire and run the voltmeter in series...
been a long time since i did it so i can't remember.
F
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Sep 2, 2005
  • Sep 2, 2005
A quick test to do would be to disconnect the wire from the sender. The guage should stay on empty.
Then take the wire and ground it to the frame. The guage should read full.
Won't tell you if it's the right guage for that sender, but it will tell you if the wiring is good.
steel1212
1,180
Frankfort, Ky
Sep 3, 2005
  • Sep 3, 2005
Also, I think they suggest that you ground it to the tank. Mine will read full for a little while but as I use up fuel it quickly goes to 1/4 tank. I'm going to run a wire back to the tank and see if that helps any.
stangman16
640
San Antonio, TX
Sep 3, 2005
  • Sep 3, 2005
Wow, that can explain why mine has a 'mind of it's own'... lemme know if that solves it for you. very interesting.
pabear89
2,126
High in the Hills of So Ca with the Voices in My H
Sep 4, 2005
  • Sep 4, 2005
Replace the sending unit.
the windings are failing on it.
Same as if it only goes partually up, when the guage reads half and your tank is full.
PB
steel1212
1,180
Frankfort, Ky
Sep 4, 2005
  • Sep 4, 2005
Mine is a brand new sending unit, doesn't mean its not bad though. I grounded my gauge to the top of the tank today...still same thing just goes to 1/4 tank. I may have to invest in a new sender. I'm probably going to check the ohms tomorrow just to make sure.
Capt Dan
237
College Station, Texas
Sep 5, 2005
  • Sep 5, 2005
Grounding it should make it go to full. I think that rules out the sender. Must be the guage or the wire. Try grounding it to the frame. Maybe you have a bad ground between the tank and the frame.
steel1212
1,180
Frankfort, Ky
Sep 5, 2005
  • Sep 5, 2005
It was grounded to the frame before I moved it. The gauge will go to full when the tank is full but quickly goes to 1/4 tank as the fuel is used.
M
1996 GT Speedometer electrical nightmare
  • moon96gt
  • Oct 7, 2026
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 17, 2026
CAMTWO1070
F
Difference between 83-86 EFI and 87-97 gas tanks?
  • ForeverDrivin
  • Mar 30, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 30, 2026
ForeverDrivin
F
Alternator not charging
  • SchwarzStock
  • Jul 6, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 17, 2026
SchwarzStock
G
1991 GT 5.0 running hot
  • gvanginkel403
  • Jul 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jul 2, 2026
General karthief
K
Electrical 2000 GT Intermittent Engine Shutdown In Motion - DTC U1262
  • kenster1092
  • Apr 13, 2026
SN95 4.6L Mustang Tech Apr 24, 2026
squeak93
