Testing the heater blower
  • Thread starter Thread starter bull999999
  • Start date Start date Jul 25, 2004
bull999999
112
  • Jul 25, 2004
I spent the day fixing the wiring on the 65 Mustang and everything works now expect for the heater blower. What's the best way to test it? I do have a multimeter.
skywalker
733
Pensacola, FL
Jul 25, 2004
  • Jul 25, 2004
apply direct power? Seems like as logical a way as any.
bull999999
112
  • Jul 25, 2004
Where should I apply the power? I noticed that there are three wires that go from the switch to the blower area to the three terminals. With the key on the "on" position, all three terminals show 12+ volts.
SnakeStang65
160
Jasper, Indiana
Jul 26, 2004
  • Jul 26, 2004
The switch provides power to 2 seperate circuits on my 65. 12 volts comes from the igniton switch. The switch then provides power out (12 volts) to one of the 2 wires going to the blower. One high speed, one low speed. The ground is provided at the motor.
Mine is diffenrent from the 66 style and up that use a blower resistor. On this type 12 volts goes to the blower motor, then to the switch that sends it to the blower resistor, then to ground.
John
skywalker
733
Pensacola, FL
Jul 26, 2004
  • Jul 26, 2004
I meant to the blower itself. The switch positions provide for 2 different blower speeds and an off position. You should also check the amperage.
However, if you apply power directly to the 2 wires on the blower you can see if the blower is working.
G
geegee
2,015
near Oklahoma City, OK
Jul 26, 2004
  • Jul 26, 2004
The early '65 has a two speed motor (two 12v windings, one ground). The late '65/'66 has a single speed motor (one 12v winding, one ground).
Early. Apply ground to the black wire. Apply 12v to the red wire. Motor should spin fast. Apply 12v to the orange wire. Motor should spin slow.
Late. Apply ground to the black wire. Apply 12v to the orange wire. Motor should spin fast.
Notes on early. Fan switch provides power (+12v) to one of the two windings via the selector on the fan switch.
Notes on late. Fan switch grounds resistor in one of three positions for high, medium or low speeds. Hi is direct connection to motor ground. Medium is resistive connection to motor ground. Low is resistive connection to motor ground.
If the motor is out of the car, it can be tested directly from a battery source voltage. You can hold it in your hand. It only has the torque of a low voltage drill motor so its not hard to hang onto.
P
I need definitive heater valve and AC expansion valve answers
  • PurAU
  • Sep 26, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 1, 2026
GypsyR
G
A
P0036 P0056 P0137 P0157 2020 Ford Mustang GT
  • AmkoA
  • Jun 16, 2026
  • 2024+ (S650) Mustang -General/Talk
2024+ (S650) Mustang -General/Talk Jun 16, 2026
AmkoA
A
Install 79-93 Mustang Heater Core Replacement
  • AeroCoupe
  • Oct 13, 2025
  • Resource Discussion Forum
Resource Discussion Forum Oct 17, 2025
85GTStangGuy
A
Engine 302 oil leak when running
  • AlexM556
  • Sep 8, 2026
Classic Mustang Specific Tech Oct 4, 2026
manicmechanic007
M
2001 v6 heater hose quick connect question
  • mnky99
  • Sep 24, 2025
  • SN95 V6 Mustang Tech
SN95 V6 Mustang Tech Sep 26, 2025
mnky99
M
