Tfi Question
  • Thread starter Thread starter nothwoods
  • Start date Start date May 21, 2014
nothwoods
85
May 21, 2014
  • May 21, 2014
I'm relocating my TFI to the fender, using a setup from a mid 90's F-series. I have the distributor and the piece of harness that plugs into the stator. My question is about the shielded wiring involved. Is it just there to prevent radio noise, or does it prevent interference with the PIP signal back to the PCM? I don't have a stereo in my car, and if that's the only issue I can just spice into the harness to extend it, but if it's going to cause any other problems I'll have to figure out how to properly shield the new section of wire.
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 21, 2014
  • May 21, 2014
Think about how much high voltage radiates from the spark plug wires, and you will realize that the shielding isn't just to prevent noise in your radio or stereo.
Simply put, shield the wire and you can be sure that it isn't a problem.
Shielded multi conductor wire - see
https://www.google.com/#q=18+gauge+3+conductor+shielded+wire.
OR
https://www.google.com/#q=3+conductor+shielded+cable&revid=1629338622
You want at least 3 conductor,18 gauge wire and a 105 C temp rating. With wire gauge, the smaller the number, the larger the copper conductor.
RacEoHolic330
I like to dress like a pretty girl
4,014
1,698
203
Allentown, PA
May 21, 2014
  • May 21, 2014
McCully racing can make you a shielded cable if you won't want to spend the effort making your own. They specialize in making TFI relocation kits. I just made a shielded cable for my cam and crank sensor wiring, and it is quite time consuming. I bought copper shielding tape on eBay to make it.
rbohm
6,698
550
204
tucson,az
May 21, 2014
  • May 21, 2014
you can buy shielded cable from a variety of sources. as i recall there are only three conductors needed.
nothwoods
85
May 21, 2014
  • May 21, 2014
Thanks for the replies. A friend of mine does a lot of electronics and computer work, he's looking to see if he has some shielded wire I can use. Seems like the shielding would be easy enough to make, I'm just not sure how to go about grounding it properly. Ill splice in at the center of the firewall where the TFI harness comes off, and the stator harness already has the shielding. Ill need to shield it from there to the TFI.
RacEoHolic330
4,014
1,698
203
Allentown, PA
May 21, 2014
  • May 21, 2014
The issue I had was finding a shielded cable that had a high enough heat rating. Most computer wiring is only good up to 70*C. The lack of affordable results is what prompted me to make my own.
You only need to ground one end of the bare drain wire in the harness. It's usually easier to ground it to wherever you're mounting your heatsink.
rbohm
6,698
550
204
tucson,az
May 22, 2014
  • May 22, 2014
make sure that any shielded cable you buy from a computer store can handle the electrical load as well as the under hood heat. remember that computer cable doesnt have to handle a lot of power.
Blown88GT
2,283
524
164
Palm Beach Gardens, FL
May 22, 2014
  • May 22, 2014
I made a shielded & grounded cable from a junkyard Ford one. Did it exactly like I designed 100 others over the years.
Everything worked except: the engine wouldn't run with the spout jumper removed. Changed back to the distributor mount & removed the extension harness & the engine runs with the spout removed.
This should tell you how important grounding & shielding is.
nothwoods
85
May 22, 2014
  • May 22, 2014
I like your car blown88, it's looks like mine except for the Cobra bumper... or least like what it looked liked a couple weeks ago before I disassembled it down to the bare shell. So far this week I have around 50 hours into modifying the electrical harnesses and metal fabrication under the hood-sorry I haven't kept up with this thread very well!
Blown88GT
2,283
524
164
May 23, 2014
#10
  • May 23, 2014
  • #10
It's not a Cobra bumper. I designed the pattern & cut it out with a hole saw & a jig saw. Under the hood, not even close. Color is probably the same, mine is original paint.
nothwoods
85
May 23, 2014
#11
  • May 23, 2014
  • #11
Nice job!
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 25, 2014
#12
  • May 25, 2014
  • #12
@Blown88GT
Only 1 end of the shield gets grounded. Which end did you ground?
nothwoods
85
May 25, 2014
#13
  • May 25, 2014
  • #13
Why couldn't you ground both ends? Is the shielding made of aluminium?
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 27, 2014
#14
  • May 27, 2014
  • #14
Only one end gets grounded. This eliminates the shield ground from carrying any current between ground points. The current creates ground loops due to the difference in voltage between the 2 ground points.
The best shielding is aluminum foil wrapped around the wiring, and covered with a copper braid and insulation.
nothwoods
85
May 27, 2014
#15
  • May 27, 2014
  • #15
I'm splicing in where the existing TFI harness comes off at the firewall, could I just wrap my new sections in foil and copper braiding and overlap a few inches of the part that leads back to the PCM? The ground for the sheilding is near the PCM.
jrichker
Mar 10, 2000
27,512
2,813
234
Dublin GA
May 27, 2014
#16
  • May 27, 2014
  • #16
That should work. Check the end to end resistance of the shield/braid. It should be less than 1.5 Ohms
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
What megasquirt kit to order
  • 74delta
  • Jul 4, 2026
  • Digital Self-tuning Forum
Digital Self-tuning Forum Aug 26, 2026
fasterthangas
F
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Electrical 88 EEC Injectors batch firing ?
  • Dustin 86GT
  • Dec 8, 2025
Fox 5.0 Mustang Tech Jan 8, 2026
gkomo
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
