TFI
  • Thread starter Thread starter Quick Pony
  • Start date Start date Aug 13, 2011
Quick Pony
129
Pensacola, Florida
Aug 13, 2011
  • Aug 13, 2011
Can someone please explain how to remove and replace the TFI for my 1991 LX 5.0 convertible.?
Do I have to remove the distributor?
I have never done anything regarding the distributor except replace the cap and rotor.
Thanks
PUNISHER RACING
1,124
FORD CITY, PA.
Aug 13, 2011
  • Aug 13, 2011
no remove the two screws and slide it down out. use dieelctric grease on the new one
dgollem
20+ Year Stangneter
May 5, 2004
212
33
49
Waldorf MD
Aug 13, 2011
  • Aug 13, 2011
Helps if you buy the "special" tool, a thin wall socket that fits in the TFI. May not be able to get it with a regular soxket. Tool is about 6 bucks at most stores. May have to turn the distributor to gain access but do not have to remove it. If you dont have a timing light mark the dizzy with a sharpie so you can turn it back to the same place. The dieletric grease is for the eletrical connection also highly recommend heat sink compound for the tfi to dizzy mating surface.
Hope this helps.
Quick Pony
129
Pensacola, Florida
Aug 13, 2011
  • Aug 13, 2011
Thanks alot guys.
Hopefully the car will start after a new TFI.
Larry
jrichker
StangNet's favorite TOOL
Mar 10, 2000
27,512
2,813
234
Dublin GA
Aug 13, 2011
  • Aug 13, 2011
The TFI module mounted on the distributor is usually the culprit for a high speed miss on a warm engine. If the problem does not occur when the engine is cold, the TFI module is definitely suspect. You may need a special socket to remove the TFI module, but most auto parts stores will have one for $5-$7.
Be sure to use plenty of the heat sink grease on the new TFI and clean the old grease off the distributor.
See Automotive Tools Specialty | Auto Mechanic & Technician Diagnostic, Testing Equipment | Thexton
K
Resolved Weird sound coming from a freshly rebuilt 5.0L
  • karhoot
  • Jun 24, 2026
Fox 5.0 Mustang Tech Jun 27, 2026
Mac131
J
Engine Tuning...?
  • justadude07
  • May 30, 2026
Fox 5.0 Mustang Tech Aug 21, 2026
Qtrhrse23
W
Engine My engine dies after running 10 to 15 minutes under high heat.
  • Wylieone
  • Jun 21, 2026
Fox 5.0 Mustang Tech Jun 22, 2026
Mustang5L5
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
