tfs 1 cam
  • Thread starter Thread starter bobbyd
  • Start date Start date May 6, 2005
bobbyd
312
San Antonio/Los Angeles
May 6, 2005
  • May 6, 2005
will it be ok to put a tfs1 cam on my car with stock heads and a typhoon intake, pulleys,exhaust,shift kit and cai?
C
cheddarbacon
82
  • May 6, 2005
ported heads
whats up man i would port your e7s and then it would be perfect you might want to get bigger injectors just a suggestion
stang22
1,318
Washington, D.C.
May 6, 2005
  • May 6, 2005
I would definately port if possible, but you shouldn't need bigger injectors with that combo. I run ported E7's, ported Typhoon and the TFS1 cam with 1.7's.
Tim
thumper460
3,022
Orange Park , Fl
May 6, 2005
  • May 6, 2005
All you need is to change the valve springs on those stockers and rock!! you will like the add'l power and the idle!! also when you install the cam, install it 4* advanced!! and then when the $$ comes around.. port the E7s or bump up !! cool??
Just me.....................
Thumper
M
mackey
1,284
Beverly, Massachusetts
May 6, 2005
  • May 6, 2005
No it wouldn't be good. The typhoon/tfs s1 are made for upper rpms, and that is where the E7s struggle. Since you do not have gears either, it will probably feel like a big loss of power down low.
bobbyd
312
May 6, 2005
  • May 6, 2005
thankx guys in the future im thinkin of porting the the e7's or buying some ported ones already thumpers.
mackey im not sure if the car has gears or not it has a shift kit but im not 2 sure if it has some gears or if it has stock ones
stang22
1,318
Washington, D.C.
May 6, 2005
  • May 6, 2005
Isn't that the purpose of having it advanced? Mine is advanced and I don't have any problems with low end and it pulls all the way through. The Typhoon is designed for 1500-6500rpm. Listen to Thumper, he knows his stuff. I agree though, gears would help out.
Tim
bobbyd
312
May 6, 2005
  • May 6, 2005
Thumper
thankx for the info. i might just go ahead and get some e7s ported with springs if i was to do this first will it be safe to put the cam after with the stock intake?
70lightning
205
in the basement makin stuff
May 6, 2005
  • May 6, 2005
You could pick up some explorer heads, and run that cam and intake.
bobbyd
312
May 6, 2005
#10
  • May 6, 2005
  • #10
i guess i should of mentioned that i have the chance of getting that intake or the e7s ported heads with springs and i dont know which ones to get first...im guessing heads right
thumper460
3,022
Orange Park , Fl
May 6, 2005
#11
  • May 6, 2005
  • #11
Dont get blown away from ALL the input!! It all will give you MORE power and Kick ass ride!! it is just that you WONT realize the full bennifit of the mods with out doing HCI !! cool?? Old school was always ..Exhaust! Induction ( Carb.. or intake or both)! Cam ! Rear end gears ! and then heads!! usually the most expensive being the last... ANY of the afore mentioned will be fun to drive!! cool?? It seems today it has to be ALL at once!! well it doesent!! and the replys here are basicly saying that... Do what you can do.. all .. part .. or what ever!! cool?? Make it fun and not a PITA and sweating out the other guy!! there are a lot of fun cars out there with Just cam and gears... Yeah, I know this doesnt help... LOL
Just me.......................
Thumper
70lightning
205
May 6, 2005
#12
  • May 6, 2005
  • #12
Thumper
I agree I was thinking the explorer heads could be had at a salvage yard for cheap is all.
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
May 6, 2005
#13
  • May 6, 2005
  • #13
not trying to steal the thread or anything but stang22....did you have to get different pushrods? if so what length did you get and what springs did you get? im doing the same setup as you are but with a cobra intake. thanks for any info
stang22
1,318
Washington, D.C.
May 6, 2005
#14
  • May 6, 2005
  • #14
I went the Thumper's #3 package with the TFS1 cam and whatever springs comes with that package. 1.7rr's, but I can't remember the size pushrods. I would have to ask my engine builder what size he used, but I want to say they were the stock length and he didn't have to shim them. I think they may have even been Ford Racing pushrods.
Tim
bobbyd
312
May 6, 2005
#15
  • May 6, 2005
  • #15
Thumper
coo thankx for all the info man
ECU5.0
Banned
Jan 10, 2004
1,803
raleigh, nc
May 6, 2005
#16
  • May 6, 2005
  • #16
Tim
awesome...thanks for the info man. guess ill have to beg the specs from thumper
Strange timing issue
  • 92 Bimini Blue
  • Sep 26, 2026
Fox 5.0 Mustang Tech Oct 20, 2026
rednotch
N
Looking for ECU/CHIP for 1992 5.0
  • Nathan26
  • Sep 26, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 8, 2026
Qtrhrse23
Engine Hiccup at full throttle
  • keel
  • Jun 2, 2026
Fox 5.0 Mustang Tech Jul 30, 2026
keel
D
N/A build on fresh stock 302
  • djcarrot
  • Oct 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 19, 2026
AeroCoupe
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
