TFS Box-R
  • Thread starter Thread starter 1991vert
  • Start date Start date Oct 10, 2007
1991vert
1,103
Ludlow, MA
Oct 10, 2007
  • Oct 10, 2007
will the TFS BOX-R intake fit under 2.5" cowl? or even a stock hood? or should i just stick to the regular style 90mm TFS-R intake
M
MustangOwner
Banned
Dec 13, 2006
160
  • Oct 10, 2007
Nope, you'll need atleast a 3 inch cowl hood to clear the R-Box. The Normal style R series intake will clear. Its great on N/A, if you go with a blower it'll suck really bad. I suggest the Holley Systemax 2 and grind the intake out to 75mm tb. IF your going with a blower. -Ian
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Oct 10, 2007
  • Oct 10, 2007
The regular TFS-R has 11 inches to the mounting flange, while the Box-R has 12.250" to the mounting flange.
A difference of 1 1/4" inches.
Ozz
I think I have a problem here.
3,514
66
109
Canton, MI
Oct 10, 2007
  • Oct 10, 2007
he's gonna have a Novi2000 to a 90mm throttle body. 75mm TB won't cut this one.
M
MustangOwner
Banned
Dec 13, 2006
160
  • Oct 10, 2007
Talk with rick anderson. I'm in the same situation as you are now. I'm copying his 748rwhp 347 stroker. I can't run a box due to clearance and he says the "Normal" R-series TFS intake sucks balls on Blower cars. Then he said your best bet is a Systemax 2 and grind it to a 75mm TB. You won't lose to much hp. Otherwise go to a box. I trust the man as he gave me dyno results on them Right now i'm deciding if i should loose my hood or go with the holley
1991vert
1,103
Ludlow, MA
Oct 10, 2007
  • Oct 10, 2007
i'll stick with the TFS over the holley.
SOLD Trick Flow Box R Series Upper Intake w/90 mm Inlet
  • Habu135
  • Apr 30, 2026
  • Engine and Power Adder
Engine and Power Adder Aug 19, 2026
Habu135
Trick Flow Series R to Box R Upper Intake Road Block
  • Habu135
  • Mar 31, 2026
  • 2 3 4
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
Habu135
Fox Xtremely high fuel consumption
  • PonyGTrider
  • Apr 11, 2026
  • 9 10 11
5K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 9, 2026
PonyGTrider
M
My numbers sound right?
  • MiltP
  • Feb 25, 2026
1996 - 2004 SN95 Mustang -General/Talk- Apr 2, 2026
MiltP
M
What's Your New Year Project Plans?
  • Habu135
  • Jan 1, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jan 3, 2026
Habu135
