I'm putting together a 306 for a buddy of mine. I installed the TFS stg 1 cam and the FRPP timing set today. I installed the short dowel pin into the front of the cam per the instructions. When I installed the large timing gear, I noticed that the dowel pin doesn't engage the timing gear all that much. It seems like the longer dowel pin would have worked better. Has anyone run into this? Am I just being a little too anal here? I'm thinking with the center cam bolt installed there shouldn't be that much force applied to the dowel, but it seems like a longer one would have worked better. And there is no way to remove the dowel once it's installed.
