I was reading about the twisted wedge heads, and looking at the differences between these two:
http://store.summitracing.com/default.asp?target=partdetail.asp&part=TFS-51400002&FROM=MG
http://store.summitracing.com/defau...t=TFS-51400004&autoview=sku&Ntk=KeywordSearch
The second one has upgraded springs (it uses a dual spring setup as opposed to single). I was reading this data sheet about the two heads:
http://static.summitracing.com/global/images/instructions/tfs-sbf_tw_sh.pdf
If I understood it right, the one with dual springs has a maximum lift of .600". Did I read that right? The reason I ask is because with the TFS Stage 1 Cam, exhaust lift with 1.7 rocker arms is .5418", which is too much for the single spring heads, but if I understood that sheet correctly, with the upgraded springs, .5418" would work fine. Thoughts?
Thanks guys!
