TFS Head question
  • Thread starter Thread starter CManT1914
  • Start date Start date Jun 19, 2005
CManT1914
3,172
Killeen, Texas
Jun 19, 2005
  • Jun 19, 2005
I was reading about the twisted wedge heads, and looking at the differences between these two:
http://store.summitracing.com/default.asp?target=partdetail.asp&part=TFS-51400002&FROM=MG
http://store.summitracing.com/defau...t=TFS-51400004&autoview=sku&Ntk=KeywordSearch
The second one has upgraded springs (it uses a dual spring setup as opposed to single). I was reading this data sheet about the two heads:
http://static.summitracing.com/global/images/instructions/tfs-sbf_tw_sh.pdf
If I understood it right, the one with dual springs has a maximum lift of .600". Did I read that right? The reason I ask is because with the TFS Stage 1 Cam, exhaust lift with 1.7 rocker arms is .5418", which is too much for the single spring heads, but if I understood that sheet correctly, with the upgraded springs, .5418" would work fine. Thoughts?
BTW, I posted this on the 94/95 section also, but there's not many of us over there right now, and I need some info quick since I bid on some nice new TW heads (dual springs) on ebay ending tomorrow.
vikingpower
656
CWU Ellensburg, WA
Jun 19, 2005
  • Jun 19, 2005
You shouldnt run a cam with more than .500 lift on the TW heads since the flow doesnt increase over that much lift, just use a cam with more duration and you wont have to upgrade the springs.
90mustangGT
I felt sorry for girls because
2,773
17
89
Dallas, GA
Jun 19, 2005
  • Jun 19, 2005
The upgraded valve springs are always a good idea.
The is more to a cam's lift than just peak lift.
CManT1914
3,172
Killeen, Texas
Jun 19, 2005
  • Jun 19, 2005
I know there's a lot more to cams than peak numbers, and I know the heads don't flow much past .500", I just need to know if it will work since I can get some 1.7's for cheap. Besides, I'm planning on getting these ported some, so they should flow a little better than even what that sheet says.
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
A
Fox Planning on building my foxbody and was wondering if I can get any tips or anything to watch out for!
  • Angelq1028
  • Oct 31, 2024
  • 2 3 4
6K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 29, 2025
Robman8028
R
Engine Heads and Cam Swap. Am I doing it right so far?
  • ClevelandTim
  • Apr 3, 2020
Fox 5.0 Mustang Tech Apr 4, 2020
nickyb
Engine 351W - Std cam or Roller?
  • ClevelandTim
  • Dec 1, 2019
2K
Fox 5.0 Mustang Tech Dec 2, 2019
vristang
SOLD 1993 Mustang GT reef blue 2 tone , 393w , 70k original miles.
  • Steel1
  • Mar 26, 2021
3K
Fox Body Mustangs For Sale (1979-93) Mar 28, 2021
Steel1
