I igotyofire Member Feb 26, 2004 774 1 19 Southern California Oct 23, 2005 #1 Oct 23, 2005 #1 Does this Cam drop right in to a stock Cobra head with the 1.7rr ?
urban96 bubb rubb says:"woo woooooo" Founding Member Sep 24, 2002 3,464 1 69 Syracuse, NY Oct 23, 2005 #2 Oct 23, 2005 #2 it goes in the block, but yeah it should swap right in
18mustangs New Member Jun 8, 2005 533 1 0 Virginia Beach, VA Oct 23, 2005 #3 Oct 23, 2005 #3 Be sure to check piston to valve clearance with those 1.7s.
I igotyofire Member Feb 26, 2004 774 1 19 Southern California Oct 23, 2005 #4 Oct 23, 2005 #4 18mustangs said: Be sure to check piston to valve clearance with those 1.7s. Click to expand... yea thats what im tryna figure out. i 4got what people say is near the max lift. and i forgot the equation to check the lift. i know its the rocker arm ratio of 1.6 or 1.7 times somthing, but i cant figure it out
B bimmertech New Member May 3, 2005 1,123 0 0 merriam, ks Oct 23, 2005 #5 Oct 23, 2005 #5 it'll clear, i run that cam with 1.7's and afr 165's. with 1.7's your lift will be .530/.542, i'm not sure your stock srpings are gonna handle that.
M Mustang95GTS New Member Feb 25, 2004 96 0 0 Oct 23, 2005 #6 Oct 23, 2005 #6 The exhaust might be close to touching. Just check PtV clearance, and you should be ok.
