The Dyno Thread
NOSJUNKE
680.1whp / 605.5lb-ft
MODS:
Engine:
Procharger D1SC
Forged MMR pro MOD 950 5.0 stroker
-balanced and blueprinted
-ford 1200hp MMR crank
-4340 Forged H-beam manley rods and ARP bolts
-forged lightweight manley racing pistons
-Speed Pro tri-metal bearings with moly rings
-MMR Ultimate oil pump (used on their 2000hp drag car)
3 core race intercooler
20lb 8-rib pulley
Kooks 1-7/8ths stepped 1-3/4 long tubes
Kooks mid-pipe
Accufab 60mm twin bore throttle body
Meizere electric water pump
AFM powerpipe
Magnaflow stainless cat-back
Professional MAS 3 made specifically for the Procharger blow throw set-up calibrated for 60lb injectors
Suspension/drivetrain:
Steeda sport springs
Steeda ‘stop the hop kit’
-IRS Brace
-polyurethane bushings
-rear IRS control arm bushings
Fidanza lightweight flywheel
Centerforce DF clutch
New clutch cable
MGW short shifter
T-56 6 speed 26-spline with upgrade billet keys and synchros
04 cobra driveshaft
Tokico D-Spec struts
Steeda full-length sub frame connectors with seat braces
4.10 FMS gears
Upgraded 10th Ann. Cobra Calipers RED w/hawk pads
Powerslot slotted and coated rotors
Maximum motorsports caster/camber plates
17 Chrome FR500 wheels 17x9 front with 275/45/17 and 17x10.5 rear with 315/35/17 summitomos
Interior:
Speed of sound dual gauge pod
Autometer phantom boost gauge
Autometer phantom fuel pressure gauge
Eclipse AVN 5435 double-din CD/DVD/NAV unit with Sirius Radio and remote
Oz Audio matrix elite 6.5 components-front doors
Dynamat extreme throughout car
Rockford Fosgate 5.25 mid-woofers for rear fill
JL Audio 450/4 4 channel amp
JL Audio 500/1 mono amp
2 JL Audio 10w3 subwoofers in custom fiberglass enclosure
JL Audio RBC-1 remote bass control knob
6-speed shift knob
MGW short shifter
Exterior:
03/04 cobra front bumper
04 Mustang black headlights
Blacked out tail lights
Window tint
Fuel system:
04 Cobra fuel tank
Ford GT fuel pumps
Zone 5 Cobra Stage II Modified FPDM
60LB Fuel Injectors
Braided stainless fuel lines with Earls fittings
Reactions: onebad2000gt
Tripoli
308 RWHP / 323 RWTQ
2002 Mustang GT Coupe
Modifications:
* Naturally-Aspirated 4.6L SOHC - Stock shortblock
* Fox Lake Stage 2 heads (2003-2004 cores w/ deeper spark plug threads)
* VT Engines Stage 2 N/A cams
* Comp Cams 26125-16 High-Load valve springs
* Steeda underdrive pulleys w/ balancer
* Ignition Solutions Plasma Booster
* Tuned by Archie at Lone Star Performance with SCT Xcalibrator 2
* Mac cold air induction
* Accufab 75mm throttle body & upper intake plenum
* Hooker long tube headers
* Hooker off-road X-pipe w/ custom cut-outs
StangNet gallery
update
Mach1Run
292 rwhp / 319 tq
Weld in Flowmaster 40s, 4.10s, Php Intake spacer, T56 transmission, Predator tune tweaked by Gearheads.
Mach1Run
305 RW / 322 TQ (STD)
298 RW / 315 TQ (SAE)
Modifications: T56 Transmission, MGW Short Shifter, Chrome 17x9 and 17x10.5 FR500s, Eibach Sportlines, Cobra Skirts, Wing Removed, Bassani O/R X and catback, PHP Intake Spacer, 4.10s, JLT RAI, Accufab Twin 60mm Throttlebody, NGK TR6, Tuned by Manny at HPP Motorsports
Update!
SaleenGT2001
375 HP 385 TQ
MODS
MPH Novi 2000 Mongoose kit 10 psi
Custom Front Mount Intercooler 24x12x3 core
Vortech Mini Race bypass valve
Built Dodge Viper T56 transmission
Aluminum driveshaft
Driveshaft safety loop
Maximum Motorsports full length subframes
Mac Off-Road x pipe
SLP Loud Mouth catback
BBK 75 mm throttle body
SCT custom tune
Lightning 90mm MAF
42LB injectors
Pro 5.0 short throw shifter
Fidanza 14lb aluminum flywheel
McCloud HD 11" clutch and pressure plate
Motive 3.90 gears
Auburn Pro 31 spline differential
Moser 31 spline axles w/ 3" studs
C-clip eliminators
Weld ProStar rims with 275/50/15 M/T Street ET radials
Autometer Lunar boost and A/F ratio gauges
Raptor shift light
Steeda clutch quadrant and firewall adjuster
SaleenGT2001
751 rwhp / 634 rwtq
MODS
Paxton Novi 2000
Tial 50mm BOV
Viper spec T56 transmission
Aluminum driveshaft
HPM driveshaft safety loop
SCT FastLane custom tune
60LB injectors
MGW short throw shifter
MGW shift knob
Fidanza aluminum flywheel
Spec stage 3+ clutch
Motive 3.90 gears
Moser C-clip eliminators
Autometer Lunar gauge cluster
Autometer Lunar boost and fuel pressure gauges
AEM wideband gauge
Raptor shift light
Cobra fuel tank Dual GT supercar pumps
SLP line lock
SCT 3000 MAF
Tokico HP shocks/struts
Cobra brakes front & rear
P51 intake
2004 Cobra crank
Ported PI heads
MPH custom grind blower cams
Manley Billet I-Beam rods
Mahle pistons
ARP head and main studs
CPR fuel rails
Oil pump with billet gear
Canton oil pan
Bassani mid length ceramic headers
Bassani off road midpipe
new ford racing block
8 Rib kit
Innovators West 10% OD crank pulley
modified FPDM
8 gauge wiring for fuel pumps
PPRV delete
NOS intercooler spray bar
NOS polished 10lb bottle and billet bracket
CPR fuel rails
8AN braided fuel line
Welded axle tubes
UPR lower control arms
UPR upper control arms
Mastrocola17
262 rwhp / 268 rwtq
1999 GT Automatic
Modifications:
Comp Cam Stage 1 Cam (262AH)
Comp Beehive Valve Springs
Mac LT Headers
Pypes O/F X-Pipe
BBK C/A Intake
Professional Products TB/Plenum
Summit Underdrives
Flowmaster Super 40 Weld-Ins
Ford Racing 4.10's
Diablo Sport Tuner
Dyno Tune
3ponyshow
351 rwhp / 349 rwtq
Modifications:
Vortech SQ trim Supercharger w/aftercooler (originally mongoose)
AODE 2500 stall converter w/B&M trans cooler
DiabloSport Predator tuned by Gil at NRP
Magnaflow X pipe (cat's) w/Dynomax stainless cat back
Koni Yellows and Sport Springs
MM full length SFC's
Ford Racing 3.73 Gears
275/40/17 Nitto 555R's (rear)
navarro98gt
292 rwhp / 307 rwtq
1998 Mustang GT Auto
Modifications:
2001 ported PI heads
CMS Stage 2 n/a cams
C&L intake plenum
75mm throttle body
C&L intake elbow
Hooker long-tube headers
O/r X-pipe
Mac catback
Steeda u/d pulleys
24lb injectors
FRPP 9mm wires
Jerry @ Sutton HP in Mattson Illinois did the tuning with an X-CAL 3.
LaserSVT
448rwhp / 460 rwtq
2003 Sonic Blue Cobra
Modifications:
BBK Ceramic Long Tubes
BBK O/R H-pipe
Flowmaster 40s
Steeda CAI
Steeda 2.81" pully
Accufab Big Oval T-body and upper plenum
Diablo Chip w/custom tune
Centerforce DFX
deftsound
428hp / 410tq
99 GT Coupe 5spd
Modifications:
Vortech SQ Supercharger
3.12" pulley pushing 10# boost
Procharger 2-core intercooler
BBK ceramic L/T Headers
BBK O/R H pipe
Stock catback with weld-in mac mufflers
Dual 03 cobra fuel pumps/stock gt tank
42# injectors
Professional products 75mm TB/Plenum
MPH Boost pipe
Motive 3.73 gears
MM Subframes
Tokico Shocks/Struts/Springs
Spec Stg2 Clutch/Flywheel
Steeda clutch firewall adjuster
Ares
320rwhp / 326rwtq
Modifications:
Stock PI heads, PI intake
Stock shortblock
Hitech Stage 2 cams
C&L upper plenum
BBK 75mm TB
Meziere Electric water pump
K&N FIPK
Pypes Longtube headers
2.5" H-pipe
MAC Catback
Fidenza Aluminum flywheel
Spec 2+ 11" clutch
FRPP 4.30 gears
Tuned By Modular Depot.
Dyno'd on a Mustang MD-250
oxfordgt
700rwhp / 573rwtq
2004 Ford Mustang GT
Modifications:
  • Built shortblock
  • stage 3 patriot heads
  • stage 3 cms blower cams
  • TFS intake
  • Novi 2000 Race version 23lbs of boost
  • AIS meth injection
  • return style fuel system
  • Mac L/T headers
  • O/R H
  • Mac catback
  • 8 rib kit
  • IW 10% overdrive
  • RR 2.7" s/c pulley
  • Thump r single bolt tensioner
  • 130 amp alternator
  • optima red top
  • meziere electric water pump
  • aluminum radiator
  • canton 7qt oil pan
  • 33 spline axles
  • c clip eliminator
  • auburn diff
  • welded and brace axle
  • stock transmission
  • spec stage 1 clutch and holding like a champ
TeufelGt
409rwhp / 395rwtq
2000 Mustang GT
Engine
Tork Tech Intercooled Magnuson M112
Exhaust
BBK Longtubes
BBK O/R H
DMH Electric Cut-Outs
Flowmaster 40 series
Drivetrain
Tri-Ax Short shift
Spec Stg2+
FFRP Aluminum Drive Shaft
FFRP 3.73 gears
Suspension
Steeda Upper Control arms
Steeda Lower Control arms
H&R springs
Exterior Mods
Cervinis 95 Cobra R hood
Mach 1 Chin
mach 1 deletion
Cobra Side Skirts
Cobra Mirrors
Chrome Saleen Reps 18x9/18x10
Nitto 555 275/35/18
Nitto NT05 295/35/18
Scicom
700rwhp / 576rwtq
1999 Mustang GT
04 Cobra short block
HPP worked heads
HPP custom grind cams
Edelbrock lower intake
T56 6 speed trans (26 spline)
Custom built hat w/LFP single blade Big Mouth throttle body
Return style fuel system w/80lb injectors, Cobra tank w/Cobra intake pump housing, 2 high flow 255 walbro pumps (gss342)
Full length BBk headers Mac cat back
Cobra front brakes
Polished F-1 Procharger (8 rib) w/3.4 pulley, my gauge only goes to 20
Eaton Posi w/3.73's
Moser 31 spline
HPM Megabite rear lowers
Steeda uppers
COramprat
322 rwhp / 306 rwtq
281 (286) bored .030 over with DSS forged rotating assembly and billet main support
Comp 278AH Cams, valve springs & retainers
6061 Plenum
FRPP 75mm TB
Victor Jr Intake
MSD Coils
JLT CAI
SCT SF3
BBK Shorties and X
Magnaflow CB
UPR FW adjuster and quadrant
FRPP 4:10's
Tri Ax
King Cobra clutch
Fidanza Alum Flywheel
Dyno Tune by Mike Lavigne of EFI Tuning Solutions
