Yesterday when I went out to the car and started it, it wouldn’t start whiteout any gas, and when I let go the gas pedal the engine dies. But when I hold the gas down for like 2000rpm in 30-45 seconds the idling start to work! Then the engine and idling worked fine the rest of the day.
And today when I and my girlfriend went to her parents the car worked fine also, no problem at all. But four hours later when we should went home the same problem come up again, the car wouldn’t work at idling. I tried several time without result. It didn’t even start idling when I hold down the gas pedal at around 2000rpm as the day before for some minute this time… So the only way to come home was to gas so the engine didn’t die and use the parking brake to brake, (manual transmission) because as fast as I didn’t gas, it just died (happened 2 times on the way home.)
Then when I come home, I plug in my OBD2 device to se if there was any codes stored in the computer, but it wasn’t. I tried to start the car again and had my foot on the gas pedal for maybe 2 minutes, and then it went idling again.
Drives the car every day, and the car has never done this before.
So what can the problem be?? Is there some idling thing that has broken??
Hope you can help me with this problem!!
The car is a Mustang GT 2001
Thanks,
Mattias
The car is a Mustang GT 2001Thanks,
Mattias
