After man hours of work, and blood shed (nice new scar on my arm) the I6 has been "restored."
Parts upgraded/replaced:
Spark Plugs
Manifold Gasket
Head Gasket
Valve Gasket (With rubber sealant)
New Battery (New Battery Tray even)
"Donut" Exhaust gasket
Cleaned out Head and pistons
Removed broken F4#@$ Bolt from head and spot welded cracks in manifold
New Battery terminals/cables
New fuel Filter
New accelerator spring
New hose lines
New spark plug/ignition wire seperators
New Air filter
Flushed and replaced coolant
Changed oil
Oil filter
Overall cost: $200
Labor cost saved: $1,400ish
I have a bunch of new tools to play with and a garage that needs to be cleaned.
When i get home tonight i will drive the car around the parking lot to let it work everything out and then will post a video for you guys. Thanks for all you help thus far and now its time to get the interior and wires upgraded, then its on to the rear end and disc breaks!
Spark Plugs
Manifold Gasket
Head Gasket
New fuel Filter
New hose lines
New Air filter
Changed oil
Oil filter
Overall cost: $200
