Okay so I have posted several times with several problems, none of which have been fixed:
1.) Car starts, runs fine in park, shift into Drive or Reverse, car will die OVER and OVER!
2.) Large amounts of heat coming from center console and up through the emergency brake.
Okay so before I was getting error codes for the thermactor air control system banks 1 and 2. Now the problems progress.
Yesterday I was at the store and I went to start my car and bam nothing. I was kinda upset at first because I just got over a battery/electrical problem. I figured out however that the problem wasn't electrical because I had plenty of power for the A/C, Radio, Lights, Keyless etc... I popped the hood didn't see anything obvious went to start it again and it started.
So I decided to drive to work, cruising about 25-30 mph at what I think was about 1300 RPM so I am accelerating and the car feels like its in neutral the RPM's rev up to about 3k while the speedometer is decreasing and then all of a sudden it hits gear again and back to 1300 it did this at least three times. I got to work and turned it off, started it again and it hasn't done this again since last night.
This morning I put it on the OBD I reader and in addition to the thermactor air control system codes I also pulled code 412 which is Unable to control RPM during high RPM self-test.
The transmission is of course an AODE and has about 16k on it, which is about 4k past its warranty. Tranny fluid is fine. While driving I sometimes hear a soft clicking noise from the passengers side of the engine compartment. Any ideas? I have a feeling this is just going to keep going downhill....
