  • SN95 4.6L Mustang Tech
the RPMs stick
  • Thread starter Thread starter EXTREMEG
  • Start date Start date Aug 31, 2008
E
EXTREMEG
  • Aug 31, 2008
got a mach1 4V 281. the RPMs stick at 2k+. i can put a load on the motor by using the brakes and get them to drop under 2k then it'll idle just fine at 700rpm at a stop. shifting is a pain cause when i put the clutch in the rpms just hang at the shift point.
i changed out the TPS and cleaned out the IAC with carb cleaner. didn't help anything tho. i have a new IAC on order. any other ideas what it could be?
96GT281
Stuart, Fl
Aug 31, 2008
  • Aug 31, 2008
its not the IAC. all mustangs do it. get a nickle and drill a 11/32 hole in the middle and shove it in the IAC hose going into the plenum. it will stop the rpms from hanging. i did it on my car and my friends
Mustang5L5
Mod Dude
Feb 18, 2001
43,366
18,112
224
Massachusetts
Aug 31, 2008
  • Aug 31, 2008
96GT281 said:
all mustangs do it.
This is the first i've ever heard of it. My car does not hang at 2K RPM's. When i press the clutch in, it drops to idle immediately all the time
E
EXTREMEG
  • Aug 31, 2008
ran the codes and got a P0122 "TPS a circuit low input". i erased the code start the car and rev to 2k or above and it hangs right at it. run the codes and it pops up again. I have a new TPS installed so i'm not sure wtf is going on with it.
Y
Y2kSlvrVert
22
Cali/LA area
Sep 1, 2008
  • Sep 1, 2008
Have you adjusted the TPS? I just replaced mine yesterday and noticed the r's hanging high. I had to turn the TPS as far counterclockwise as it would go for the right idle. Voltage readings were good...1.0vdc - 4.89vdc. Maybe the throttle blade or linkage is sticking. Also check EGR.
E
EXTREMEG
  • Sep 1, 2008
everything on the TB looks good opens and closes normal. thing i noticed today when i checked the volts there's only one wire with any current. there are 3 wires the bottom one is the only one that pulls a current. the one in the middle goes to 1 but that's it.
96GT281
Stuart, Fl
Sep 1, 2008
  • Sep 1, 2008
not all but i've heard of a lot that do it. mine did. i did the nickle trick and no more hang
L
Engine 85 GT Excessive Idle
  • lutzkecj
  • Sep 18, 2026
Fox 5.0 Mustang Tech Sep 21, 2026
86HO5.0
  • Gulftown980x
  • Jul 29, 2026
squeak93
K
2003 GT High Idle, vac leak process
  • krysber
  • May 11, 2025
SN95 4.6L Mustang Tech May 11, 2025
krysber
K
A
Rough idle - cylinder 1 and 6 misfire HELP
  • austindavies935
  • Jul 24, 2025
SN95 4.6L Mustang Tech Jul 24, 2025
gkomo
O
Need a hand: Hanging idle with all new parts
  • Overused03
  • May 15, 2024
SN95 4.6L Mustang Tech May 21, 2024
Overused03
O
