D daveinfl33777 Member Nov 3, 2022 46 2 8 Florida Jan 11, 2025 #1 Jan 11, 2025 #1 Is it normal for the theft light to always be on...even with the car off and key out it always stays on?
Noobz347 Stangnet Facilities Maint Tech... Er... Janitor Admin Dude Jan 4, 1985 43,535 21,704 234 Box behind Walmart Jan 11, 2025 #2 Jan 11, 2025 #2 Not normal. Weak battery Faulty ignition switch Aftermarket alarm system PATS key transceiver problems Do you have a code reader?
D daveinfl33777 Member Nov 3, 2022 46 2 8 Florida Jan 11, 2025 #3 Jan 11, 2025 #3 Noobz347 said: Not normal. Weak battery Faulty ignition switch Aftermarket alarm system PATS key transceiver problems Do you have a code reader? Click to expand... I do have a code reader yes
N newedge2001nc New Member Feb 5, 2026 1 0 1 Greensboro, NC Feb 5, 2026 #4 Feb 5, 2026 #4 I have the same issue. Light is on 247 but still starts and runs fine. However, it is draining my battery. Also, it used to just blink 247 and run fine. Now it is a solid on 247.
