Theoretical Towing Capacity
  • Thread starter Thread starter RandomSlacker
  • Start date Start date Nov 3, 2015
R
RandomSlacker
  • Nov 3, 2015
Ok ive got an odd theoretical quesrion. Well sort of serious....
How much weight could a sn95 mustang be made to pull?
Factoring...
302 and trans built for pulling.
More than adiquate brakes.
And the most important factkr... The load has zero tounge weight.
Thanks to my crazy pondering of pulling a header trailer with the car instead of the semi.
Adieu
Easy there, this ain't a dating site.
20+ Year Stangneter
Mar 7, 2002
9,531
5,187
224
Nov 3, 2015
  • Nov 3, 2015
Not much.
Even with zero tongue weight, an SN95 mustang is still a fairly flimsy unibody car. Adding subframe connectors and bracing the floorpan and body in other ways would help slightly, but your suspension mounting points would still be subject to excess stress when pulling any significant amount of weight.
If you're wanting a car that can pull, you need any full-frame Ford Panther-platform car (1979+ LTD Crown Victoria, Crown Victoria, Marquis, Grand Marquis, or Town Car), or any of the full-size '70s Ford with a full frame. My '75 Thunderbird, for instance, was factory rated to tow 5000lbs, and would've been rated for 6,000 had it been optioned with the rear disc brakes if I recall correctly. (I only pulled with it once, yanked a 4x4 Ram out of a ditch with a tow strap. 460ci V8, C6 trans, 9" rear... piece of cake.)
Uni-body cars just aren't meant to pull significant loads in general, that's why most have ratings of 1500lbs or less, or specifically state in the owners manual not to tow. There are exceptions, and the whole segments of uni-body SUVs and CUVs that can tow a bit more (usually around 3500-4000lbs).
R
RandomSlacker
  • Nov 4, 2015
Thats the exact reason why i came and asked that here.
Thanks.
RangerJoe
I leave the horn on while driving
2,560
1,146
184
Georgia
Nov 4, 2015
  • Nov 4, 2015
Check out some of the drag week guys. They pull very small trailers with drag slicks and tools on them. I would guess less than 1000lbs.
Joe
Adieu
20+ Year Stangneter
Mar 7, 2002
9,531
5,187
224
Nov 4, 2015
  • Nov 4, 2015
RangerJoe said:
Check out some of the drag week guys. They pull very small trailers with SD lucks and tools on them. I would guess less than 1000lbs.
Joe
Some of those guys are even running back-halves and cages, and they still tow less than 2000lbs in equipment, tools, spare parts, etc.
89oem
Mustang Master
Dec 18, 2013
1,456
542
144
Nov 4, 2015
  • Nov 4, 2015
I towed a 22 foot bow rider with a 350 mercruiser in it with my vert , 100's of miles for several years, it was dual axle and had surge brakes, car was bone stock.
iirc dry weight was over 2800lbs tongue by scale was around 500
I had no frame or body twist at all, I did however roast the stock flywheel I discovered when I had the clutch replaced. My guess is from pulling up steep boat ramps...
Still own it and even on full panel tear down during a recent refresh we could find no evidence of any issues.
Frame twist comes from heavy torque applied by drag racing, heck its a 302 truck motor it'll pull whatever you want within reason..
R
RandomSlacker
  • Nov 4, 2015
Lol. My duck boat is 300lb on trailer and it's the only thing i pull with my own vehicles other than my 5th wheel.
My average load is 60k tho.
rbohm
6,698
550
204
tucson,az
Nov 4, 2015
  • Nov 4, 2015
you could probably pull up to about 10,000lbs, given an upgrade in brakes, cooling system, etc. and using a stinger to eliminate the tongue weight. that said however why would you want to pull more than a couple thousand pounds at most?
Bullitt347
I have been doing it wrong this whole time
4,068
3,140
204
Middle of Maine
Nov 4, 2015
  • Nov 4, 2015
I would like to see that. A 10,000 lb trailer being pulled by a 3,500 lb car. No worries..Lol. The 10,000 lb trailer would make that car it's B**ch.
Reactions: A5literMan, Adieu and Boosted92LX
Boosted92LX
5,721
4,244
224
Nov 4, 2015
#10
  • Nov 4, 2015
  • #10
10000 lbs on my fx4 f150 makes it the same thing.. lol. People who don't pull trailers regularly don't understand getting it rolling is only part of the equation. Handling it and braking are what you need to be concerned with. I know a man who is crippled and lost his whole family when an 18 wheeler pulled out in front of his powerstroke and 5th wheel camper. He couldn't stop it in time and the truck was crushed. NO WAY IN HELL I'd pull a boat with a mustang unless it was a little john boat.. and then I'd still feel silly.
Reactions: A5literMan and Adieu
R
RandomSlacker
#11
  • Nov 4, 2015
  • #11
Biggest reason this became a thought is because i hate driving 30minites south to get a semi to haul a header trailer there from an hour north, that the 302 and trans i am getting ready for mycar are more than capa le of pulling.
Unlike the camper scenario... Our header trailer has its own brakes, that WORK, so all your doing is providing pulling and control. It falls under the discriotion of a 'stinger'.
Boosted92LX
5,721
4,244
224
Nov 4, 2015
#12
  • Nov 4, 2015
  • #12
FYI: The camper had brakes that worked. Highway speed with no lane to change into, and the genius in the 18 wheeler merged in at 5 mph. The camper, brakes locked up, drove the pickup under the semi trailer. Inertia and a trucker's stupidity killed several people, and left a man without his family. I see that kind of thing way too often with truckers come to think of it...
rbohm
6,698
550
204
tucson,az
Nov 4, 2015
#13
  • Nov 4, 2015
  • #13
well i never said that it would be in any way easy, just that it could be done. i would seriously doubt the sanity of ANYONE that would try such a thing. i was merely observing that it could be done, not that it should be done.
so ths would be for pulling the stinger that sets up semis to run doubles? as i recall those things weigh in at about 3000lbs or so, am i right?
if so then perhaps your mustang could pull one, however i would not recommend such an endeavor.
Reactions: Boosted92LX
What's your tow rig?
  • LILCBRA
  • May 31, 2026
  • Other Auto Tech
Other Auto Tech Oct 23, 2026
JH96GT
Definitely not a new member (joined in 2005), but beyond searching I'll finally be posting:) New to me 1983 4-Eye Notch in my possession now:)
  • bahndrvr
  • Jan 31, 2019
  • The Welcome Wagon
4K
The Welcome Wagon Feb 8, 2019
Olivethefet
Fox T5 To Aod Conversion
  • 86GTVert#2
  • Jun 29, 2016
3K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 30, 2016
86GTVert#2
Progress Thread 64.5 Coupe - Xsboost90's Build Thread
  • xsboost90
  • Aug 13, 2013
  • 2 3
31K
1965 - 1973 Classic Mustangs -General/Talk- Jul 29, 2017
todd h
9
  • Locked
Expired 94gt Bolt Ons Nj $1000
  • 95PGTTech
  • Dec 19, 2013
11K
SN95 Mustangs For Sale (1994-04) Dec 19, 2013
95PGTTech
9
