They don't work the egr. That's a separate system sending the exhaust gases back into the system for reburn and cylinder temp reduction.
The thermactor system sends fresh air from the pump to either the heads or cats. The bypass solenoid sends vac to the bypass valve (valve closest to the pump) to control whether the fresh air is sent to the atmosphere or down the line to the next valve which is the diverter valve. The diverter solenoid sends vac to the diverter valve (furthest from the pump) which has 2 hoses going off of it either to the heads (upper hose) or the cats (lower hose).
At idle the air is going to the heads to increase temps for cleaner emissions. Once the cats heat up, the fresh air is diverted to them in order to provide cleaner emissions.
if you're throwing codes for those solenoids (81 and 82 i believe) and have a DMM handy, check the resistance across each solenoid, should be 50-100 ohms, if not go junkyard diving
