I have an 88lx (na). Lately its started overheating and everyone has suggested that I change the thermostat. Also they all stressed it was extremely easy. As far as changing the thermostat goes that was easy. The problem arises when I put it all back together and start the car. I end up with coolant dripping around the seal (or spraying depending on how long the car has been running). The first time I figured I had just rushed through it and didn't take the time to get the old gasket off completely. The 2nd time I took my dremel and made sure the old gasket was off and everything was smooth. Put it back together and the same problem. I bought some "super blue gasket maker" and tried that, same problem. (I didn't use a physical gasket because I'm assuming the "gasket maker" replaces that.) Am I supposed to use both the gasket and the gasket maker?
What am I doing wrong? I'm thinking about just taking it somewhere and having someone else mess with it to end my frustration.
Thanks ahead of time for any help!
