  • 1994 - 1995 Specific Tech
Thermostat questions
  • Thread starter Thread starter King Cobra 22
  • Start date Start date Nov 29, 2005
K
King Cobra 22
175
  • Nov 29, 2005
My car runs on the cool side even in hot florida with the stock H/C/I.
I was wondering will my car run hotter with the new H/C/I?(TrickFlow kit)
If so I was thinking about getting a 180 thermostat.
I talked to a mechanic and he told me that running a 180 degree stat would waste more gas and would not be good for the motor.I could get problems like oil sludge yada yada yada.He told me engines run better when it's a little on the hotter side like a 220 degree stat.
Whats the truth here? I'm very confused.
And Will I waste more gas?
legalize420
1,541
South Florida
Nov 29, 2005
  • Nov 29, 2005
im in florida and i use a 180 with no problems
HISSIN50
34
129
Nov 29, 2005
  • Nov 29, 2005
So this guy is recommending a stat that is 20-25*F hotter than stock. Your low speed fan would never shut off once the car reached temp.
No offense, but that is some horrible info.
You need to look at what temps your car runs at, not the stat rating. But a 180 allows the ECT to get into full fuel trim, and that is what matters IMHO. I also run a 180, as do most folks on here.
Good luck.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Summerville,SC missing South Fl. weather :(
Nov 29, 2005
  • Nov 29, 2005
180 stat here for the last 3 yrs. no problem.
K
King Cobra 22
175
  • Nov 29, 2005
Good luck.
He was mostly talking about cars in general.
Like you said most people here run a 180 stat and when I brought up thermostats to this mechanic he told me my car would run better at a higher temp(not too high) basically recomending me to keep the stock stat which I believe is what something like a 200? Instead of getting a 180 stat.
W
wytstang
Mustang Master
Mar 14, 2004
4,988
Nov 29, 2005
  • Nov 29, 2005
Stock stats are 192 (our cars)
HISSIN50
34
129
Nov 29, 2005
  • Nov 29, 2005
KC, I guess we should ask: where do you live (climate-wise)? And what engine-temps do you run at right now? And In the summertime? If you live in a cold climate, do you drive the car in the winter? (give folks a temp range that your car sees, and how well it does in those extremes).
In trying to figure out what the guy meant, here is where he may have been coming from:
I would use a stock stat if I had to drive in the cold winter.
The other thing he might have been thinking of was that many many folks think that if a little is good (a 180), more is better (a 160). This is not so, and if he was talkin about 160's, I agree with him.
So I guess more info about your personal set-up would help folks to figure this out and maybe help ya make a good decision.
Good luck.
94GTLaserRC
Squint as you approach, lest you be blinded by my
11,178
Ernan Says "here it comes... dushbag"
Nov 30, 2005
  • Nov 30, 2005
Get a 180, make sure your fans come on (test with code reader) and be done with it!!
RC
K
King Cobra 22
175
  • Nov 30, 2005
Good luck.
For my climate I live in Florida. I don't know the exat temp my car runs at but by going from the gauge It runs on the cool side of the gauge no matter what temp it is outside.Summer time is usually 90+ degrees and winter is usually in the 40's (coldest).
If my car is running cool maybe I wouldn't need a 180 stat?
Will I run hotter with new H/C/I?
HISSIN50
34
129
Nov 30, 2005
#10
  • Nov 30, 2005
  • #10
The stat should regulate temps to its rating, so it does not really matter. As you can see, other guys in FL use the same stat (as do I, in the desert. Temps of 115*F to freezing and below).
Most important with the HCI is that you dont want to take a chance on running alum heads too hot. I would use a 180 on the HCI, even if in a milder climate. That is just me - others might vary.
Good luck.
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
424
154
Boca Raton, Florida
Dec 1, 2005
#11
  • Dec 1, 2005
  • #11
HCI will generate more heat. A 180 stat, the fan coming on early (instead of 210), 60/40 mix (water/coolant) and a bottle of water wetter should easily knock 20 degrees off. To go even further then that I would suggest an aluminum radiator. My car runs at about 180 degrees all the time with all this in 90+ degree Florida weather.
94GTLaserRC
11,178
Dec 1, 2005
#12
  • Dec 1, 2005
  • #12
I didnt know your car was running
RC
VibrantRedGT
424
154
Boca Raton, Florida
Dec 1, 2005
#13
  • Dec 1, 2005
  • #13
RC
When it was running. That with a blower to boot.
94GTLaserRC
11,178
Dec 2, 2005
#14
  • Dec 2, 2005
  • #14
Get Her Runnin' already!!!!
Then take a drive by!
RC
VibrantRedGT
424
154
Boca Raton, Florida
Dec 2, 2005
#15
  • Dec 2, 2005
  • #15
Almost done, should be soon.
ProKiller
3,064
15
78
PA
Dec 2, 2005
#16
  • Dec 2, 2005
  • #16
i run a 180 don't go any lower. something else that guy might be thinking about is the sensors. most sensors only start to be accurate once they reach a certain temp. Rick at AFM told me that the sensors for us don't work properly if they are too cool.
94GTLaserRC
11,178
Dec 2, 2005
#17
  • Dec 2, 2005
  • #17
M
Resolved 1988 Foxbody - Overheating Summer
  • MDrisc
  • Oct 26, 2025
Fox 5.0 Mustang Tech Jul 17, 2026
fasterthangas
F
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
W
High Cylinder Head Temp - Not Overheating?
  • wtfwork12
  • Jun 26, 2025
2K
2005 - 2014 S-197 Mustang -General/Talk- Jul 1, 2025
wtfwork12
W
  • B0udreaux
  • Jul 14, 2026
AeroCoupe
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
